To those of you who converted your ECU to OBD1, please read....
Old Feb 16, 2003 | 10:36 AM
JDubya's Avatar
Default To those of you who converted your ECU to OBD1, please read....
once you put the new ECU and conversion harness back in the car, how did you have everything positioned so you could get that plastic kick panel back on?
Old Feb 16, 2003 | 10:41 AM
StinkyTofu's Avatar
Default Re: To those of you who converted your ECU to OBD1, please read.... (ALL MOTOR LS)
I'd like to know this also. I'm guessing if you can't get everything bolted up the way it is from the factory with the stock ecu, you can probably use masking tape to mount it. Sure its ghetto, but you won't see it right?
Old Feb 16, 2003 | 10:49 AM
JDubya's Avatar
Default Re: To those of you who converted your ECU to OBD1, please read.... (StinkyTofu)
like the ECU will bolt to the car, its just that b/c of the conversion harness, there's a lot of excess wires and all that get in the way of putting the kick panel back on.
Old Feb 16, 2003 | 11:30 AM
Audio28's Avatar
well i couldn't bolt it back on cause of all the wires. but i had the plug facing down, and the wires facing the the inside. hope this helps, i'll try to post a pic when i get home.
Old Feb 16, 2003 | 02:27 PM
JDubya's Avatar
Default Re: To those of you who converted your ECU to OBD1, please read.... (Audio28)
coo, were you able to put the kick panel back on or no?
Old Feb 16, 2003 | 02:47 PM
neo1z's Avatar
You just need to tuck the conversion harness wires under the ecu the best you can...I'll try and show a pic of what I mean, I just put my panel back on this weekend.
Old Feb 16, 2003 | 03:34 PM
PM-Performance's Avatar
Default Re: To those of you who converted your ECU to OBD1, please read.... (neo1z)
mine went back in fne , just gotta finagle it a bit , i wetn from my stock R ecu to a p28 that is double the size
Old Feb 16, 2003 | 06:40 PM
maggsgsr's Avatar
Default Re: To those of you who converted your ECU to OBD1, please read.... (itr206)
What I did was you a twisty tie to hang the connectors coming from under the dash under the dash,put the metal guard over the ECU with the connectors facing up coming out of the plastc kick panel and connected in the back under the glove box.The heavy duty twisty ties keep it underneath& behind the glove and you cant see it at all.
Old Feb 17, 2003 | 03:08 PM
JDubya's Avatar
Default Re: To those of you who converted your ECU to OBD1, please read.... (maggsgsr)
thats what i was kind of trying. i just gave up b/c there was already like a foot of snow out there and it just kept pilin up. i'll try it tomarrow and see how it works out.
Old Feb 17, 2003 | 03:58 PM
UnionCity LS's Avatar
i have a question..p28..is that my ECU on my Ls? casue i was cleanin under the hood today and i seen a black cover with p28 on it..next to my AEM power pulleys..and i was wondering what is a obd1? cause i see it quite often on here and.. i dont know to much about these things..and i was wonderin what would be a good brand ECU upgrade for my 99 Ls..headers, exhaust, pulleys, CAI.?
Old Feb 17, 2003 | 05:11 PM
maggsgsr's Avatar
Default Re: To those of you who converted your ECU to OBD1, please read.... (UnionCity LS)
Its a good mod thought,just with bolt ons and my 95p72 you can clearly feel a difference during vtec,it even sounds alot meaner.
craig88crx
Mar 16, 2010 04:36 PM
driftam1
Apr 25, 2008 09:13 AM
civc_tt
Aug 16, 2006 02:37 AM
psycho.chicken
Jul 12, 2006 10:12 AM
Keri's_baby
13
Dec 20, 2005 04:51 PM
