Cam gears or exhaust?
Old Feb 16, 2003 | 09:30 AM
MooreBoost's Avatar
Default Cam gears or exhaust?
I had my JRSC pulled and sent off because it was chattering. I decided to get some work done while my car is out. I told him I was going to do cams sometime later in my build, so he said to do cam gears. Now, I have no problem spending money on my car, if it will help. But, I have a N1 exhaust, and I just got my silencer, I will NEVER run without it again, I got too tired of the noise. So, my question.....If this silencer is totally robbing power, especially under boost, should I hold off on the cam gears and get a different muffler? If so, what muffler should I get welded up? Thanks,
gmoore
Old Feb 16, 2003 | 09:42 AM
tilt's Avatar
Default Re: Cam gears or exhaust? (gmoore379)
How about the Apex'i WS ? I believe it bolts right up to the N1 piping.
Old Feb 16, 2003 | 10:03 AM
MooreBoost's Avatar
Default Re: Cam gears or exhaust? (tilt)
Good idea...but wont it cost an arm and a leg? I couldnt care less how it looks....So I may as well go to a muffler shop and get a generic bolted on, just making sure it was good diameter inlets and outlets. Anyone else?
gmoore
Old Feb 16, 2003 | 10:10 AM
trustbuddy's Avatar
don't get a generic muffler.....for your n1 i don't think there is too much power difference between using the silencer and not using the silencer...just drive around with the silencer on and later when you feel like hearing your exhaust noise again, take if off....spend you money on something else.
Old Feb 16, 2003 | 12:55 PM
Audio28's Avatar
Default Re: Cam gears or exhaust? (trustbuddy)
i agree with thrustbuddy. Don't buy another exhaust. The silencer ain't restricting 10 hps or anything. spend on something else.
Old Feb 16, 2003 | 08:53 PM
redhnda's Avatar
New User
Go with the cam gears. Tune it's right. It'll worth the money.
Project_EK
25
May 12, 2005 06:21 PM
obsidianG35
Nov 21, 2004 04:39 PM
TrueUntilDeath.com
Jul 17, 2004 10:53 AM
pickieman
Dec 18, 2003 05:35 AM
pickieman
Dec 17, 2003 07:56 PM
