Camshaft removal question
I've seen differing instructions for this.
One way says to loosen all the valve springs before taking off the cam. The other way leaves the valve springs as is.
I'd like to leave my valve springs alone since the head will be reinstalled with no work done on it.
Is it OK to remove the Camshaft with the valve springs still tightened? Is there any special order I should remove things in to do it this way?
TIA
TIA
wunfstgsr
Nov 21, 2012 11:36 PM
