Modding Your Power Window Motors (can it be done)
As the topic says... is there anyway to upgrade or replace the motor on your power windows (i have a 99si)
it takes for ****** evar for my passenger side window to roll up and I know its not my damn car batterey!!!
do you have to buy like the whole contraption assembly or is there any websites (im googling as we speak) that sell custom kits for that type of ****...
I know some people get power windows installed on manual mirror cars and there obiously is a way to hook a motor up to that stuff...
someone please advise
Just put some nitrous on it! Just messin'.
As for a serious note of help, try looking at other model Honda/Acura cars that have a faster window mechanism and if you don't, move onto trying other cars.
is it just me or is the passenger side window always slower on a honda i'm going to try the Silicon spray
, it seems like my driver's window goes down a little slower than my passenger
I have a 98 coupe.......same problem. Passenger side window goes sooo slow.
two of my other buddies have eg's wiht pw and they go up and down like there new. one of my friends eg has 250k miles on the body and still goes up and down like a champ.
[Modified by Kp_VtekNiks, 2:13 AM 2/17/2003]
Have you tried silicon spray along the window track? I used it when my windows were going slow or getting stuck.
Works like a charm.
Works like a charm.
Use the wet type, get it on the track inside the door and in the rubber seal part up top......
damn dude, i thought i was lazy.
are u seriously asking how to mod ur power window motor????????
his next post is gonna be:
HOW MUCH BOOST IS SAFE FOR UR WINDOW MOTOR?
damn. I was wondering all this myself, didn't really think about it though
I'll have to go buy me some silicon spray that my girl used to enlarge her ::cough::
and migs! more info yo
you better fix it before it messes up.... my driver side window was doing the same thing... and the arm that holds the window snapped.... and the window came down and got scratched.... so i took it off and welded it back together..... the lube works... had to do it to my passanger side too.....
welp i found something today online how to take all of that **** apart, so im just going to take the windows and the tracks out of the door and clean the track as best as possible.. the car has been broken into a couple of times, the window was broken on that side once, and also pryed into so im sure that will help it...
if the **** still rolls up slow when i slap it all back together im just going to buy some honda accord motors...
Guest
Posts: n/a
Its not your motor. Its the regulator. Theres a technical service bulletin on this, it happens to 96+ cars. the regulator needs to be replaced. Ive done both doors on my 96. Easy 30min job. about 30 for the part.
mine sounded like I had sand in the grooves when the window went up and down, like three weeks later the window stopped working, 96-98 civics use a wire attached to a motor to roll them up and down. what happened was the wire became stray and starting coming apart, the grinding I heard was the wire getting bunched up inside the pulleys, all in all it sucked.
wizarddrummer
Sep 4, 2012 10:44 AM
