ATTN: oldschool hybrid board members (help!)
Can anyone give me the e mail adress or adress'es of the people who made this article:
http://hybrid2.honda-perf.org/tech/bigbrakes.html
reason:
I have still been unable to find a solution in finding REAR DISC replacements for the jdm 96 itr 4x114.3 suspension on my hatch. THe US GSR brakes are a slight bit smaller in the circular section that goes onto the HUB. It needs to be exact. THey are the same widith/height. but the center piece isnt the same. if you have a way to make them fit? or know the ACTUAL replacement that will work. lemme know. thanks!
reason:
like i said. The prelude ones DID NOT work. i ordered them and tried them. yes there the same bolt pattern. no they dont fit with the caliper/etc... And i did have GSRS redrilled as well (more money down the toilet). the center piece that connects to the hub is slightly smaller. but slightly enough to where it doesnt fit... any help would be apreciated
call aj-racing.com they might be able to get you a pair from JDM.
the problem with the JDM 4bolt is that the hub is pushed out 5mm then GSR/Si rear discs. while the redrilled 5-bolt would work but then the problem occurs with the size of the rotor.
if you want some used rear discs for your JDM 4 bolt let me know I might be able to get you a pair.
unclemr2
Mar 15, 2010 09:08 PM
bleke
Suspension & Brakes
Nov 12, 2007 04:08 PM
JMX
Dec 25, 2002 03:53 PM
