My buddie's CRX went crazy yesterday
Old Feb 15, 2003 | 08:24 PM
CXHatchback's Avatar
Default My buddie's CRX went crazy yesterday
He said he was driving and the tach started jumping up and down along with the engine with about a grand of play. I went for a ride with him to check it out and the engine seems fine, but the tach was going nuts at times. Anyway, sounds like a sensor or something going bad, anyone have an idea? Also, would the sensor be in the cluster or on the engine somewhere? I'm guess in the engine bay since the rpms were going nuts. Thanks
Old Feb 15, 2003 | 08:31 PM
MilanoRex's Avatar
Default Re: My buddie's CRX went crazy yesterday (CXHatchback)
Same thing happened to my old crx... there was a short in the wire. Did he install an external tach?
Old Feb 15, 2003 | 08:32 PM
singlecam screamer's Avatar
well it sounds like a ground wire problem have him check all his groundson the motor if not have him add one to the tranny
Old Feb 15, 2003 | 08:35 PM
Tofurky's Avatar
the distributor, or the ignitor. or maybe just a loose wire somewhere
Old Feb 15, 2003 | 08:40 PM
Default Re: My buddie's CRX went crazy yesterday (Ruckus138)
Cool, we'll check all that tomorrow. Also should've mentioned, it's a bone stock auto (he's not a car guy, but some how he found a crx with 50k miles on it and chose to do nothing with it ) and he just replaced the distributor.
Old Feb 15, 2003 | 08:54 PM
IWearMyKswiss's Avatar
New User
is the car losing power??? could be the alternator
Old Feb 15, 2003 | 08:58 PM
Default Re: My buddie's CRX went crazy yesterday (WiDeBoDyEK)
Nah, that seams fine. I know what you're talking about though, I've experienced that jerking when an alternator is taking a ****. He described a similar feeling when this happened but apparently is wasn't that. I thought at first it was just his cluster that was fucked up.
Old Feb 16, 2003 | 05:32 AM
Default Re: My buddie's CRX went crazy yesterday (MilanoRex)
Nope, any other ideas?
Old Feb 16, 2003 | 01:46 PM
Still can't figure out the problem, it's bone stock, new distributor, and the grounds all seem fine.
Old Feb 16, 2003 | 01:51 PM
hanson said's Avatar
doesn't the crx have a cable speedo? if so, the cable might be a little f'ed up internally. might be something to check on. might be even better to ask this in the crx forum, where the gys know all about crappy parts and gremlins like this
Old Feb 16, 2003 | 01:57 PM
civbeater90's Avatar
Default Re: My buddie's CRX went crazy yesterday (hanson said)
check ignitor that is almost always the first sign of one going bad
Old Feb 16, 2003 | 04:24 PM
Full-Race Henry's Avatar
same thing happend to me, it was the distributor
Old Feb 16, 2003 | 04:29 PM
Default Re: My buddie's CRX went crazy yesterday (EF8_Fan)
Now that's wierd. He just spent 400 cause he was stuck an hour away to replace the distributor when I told him we could've done it, and then spent another 600 on replacing the radiator. That would really suck if it's the dizzy though.
Old Feb 16, 2003 | 05:56 PM
1stealthls's Avatar
hey my rex did it till the main pick up in the dizzy like melted?????weird
but my teg did it and it was a loose ground duh the one at the thermostat
sounds more like a dizzy cuz mine was going crazy but ran fine my teg would jump crazy but would also spit and sputter and sometimes wouldnt even start also sounds like he made a bad disc..........but u gotta do what u gotta do
Nevadertonian
Sep 21, 2012 10:27 AM
Canadian_EF
Mar 27, 2009 03:23 PM
Firefoxracer
Nov 22, 2006 01:32 PM
PINKS
17
May 14, 2006 05:07 AM
hybridbmw
Jul 15, 2002 12:59 PM
