Question on NGK Wires & Plugs ----->
Old Feb 15, 2003 | 04:45 PM
sirminder's Avatar
Default Question on NGK Wires & Plugs ----->
I originally posted this in the Tech forum, but did not get any responds. Hopefully I would have better luck here...
Im looking for BRK6E-N11 but NGK's site says the replacement is PFR6L-13 which are platinums. Is there any other available like copper and others? Also, wire set is HE64, what color do these come in?
This is for a 2nd gen B16 in a 5th gen civic. I used the 95 DOHC Del Sol's profile to get the results. Thanx.
Old Feb 16, 2003 | 04:39 AM
sirminder's Avatar
Default Re: Question on NGK Wires & Plugs -----> (sirminder)
ttt
Old Feb 16, 2003 | 04:30 PM
sirminder's Avatar
40+ views and no response? Come on, there has got to be someone with a B16 runing on NGK's.
Old Feb 16, 2003 | 04:37 PM
poison's Avatar
IMO, any of the NGK's plugs are by far awesome.
NGK platinums are great for high compression.
as for the HE64's, I think they only come in black, I thought I might have seen blue though.
Old Feb 16, 2003 | 05:42 PM
sirminder's Avatar
Default Re: Question on NGK Wires & Plugs -----> (poison)
Thanx for the reply. But as far as the NGK Copper's go, where would I be able to buy them? Im still interested in getting the Platinums, but I want to know more about the diff between the two.
Old Feb 16, 2003 | 05:52 PM
poison's Avatar
I am not sure on where to purchase the NGK Coopers. But as for the NGK Platinums, they just have a cooler burn resistance so you can run higher cylindar temperatures (such as high compression, nitrous, etc.)
Old Feb 16, 2003 | 06:00 PM
function83's Avatar
those bkr6's are cold plugs cuz they are gapped more than stock plugs.
[Modified by djhatch, 3:01 AM 2/17/2003]
Old Feb 16, 2003 | 08:28 PM
sirminder's Avatar
Default Re: Question on NGK Wires & Plugs -----> (djhatch)
How can they be colder than stock, if Honda recommends them as stock?
[Modified by sirminder, 5:33 AM 2/17/2003]
Turbo-Tec
11
Aug 19, 2005 02:17 PM
knowtomorrow3001
Dec 31, 2003 12:59 PM
sirminder
Feb 16, 2003 08:25 PM
prelude10
Feb 1, 2002 06:16 AM
