what is this??pic
Old Feb 15, 2003 | 02:32 PM
iwouldHITit's Avatar
Default what is this??pic
its a black box that all my vaccum lines go into?when i put my b18 in do i still need this and connect the vac lines from the b18?
[Modified by iwouldHITit, 11:33 PM 2/15/2003]
Old Feb 15, 2003 | 02:34 PM
I Gotta Question's Avatar
Default Re: what is this??pic (iwouldHITit)
Emisions crap I think.
Old Feb 15, 2003 | 02:39 PM
silverCRXTC's Avatar
Default Re: what is this??pic (89_CRX_HF)
that is the crx hf map sensor, its exchangable with the map sensor from the si and dx (even sir), if (when) you do a swap, that map sensor has extra hoses for the hf only, i would sugest swaping this too a si unit so,
1.)you dont have extra hoses in your engine bay
2.) your swap runs better, (i believe) that map sensor has more "economia" purpose and a si unit would increase your performance.
Old Feb 15, 2003 | 03:36 PM
brian g's Avatar
Default Re: That contains....
That contains the MAP sensor, purge cutoff solenoid and EGR activation solenoid.
brian g
Old Feb 15, 2003 | 08:02 PM
eccentric.ek's Avatar
Default Re: That contains.... (brian g)
yep, only hf's have that i think
Old Feb 15, 2003 | 08:12 PM
Outsane's Avatar
Default Re: That contains.... (redUSDMhb)
All of the 88-91 CRX's I have see have it..it's just not in a box..and the sensors are exsposed..
Old Feb 16, 2003 | 04:04 AM
Default Re: That contains.... (Outsane)
so when i swap my b18 in i can just hook up all the vaccum lines form the b18 to the box.??
does any one know a good site that may help me more on the swap?
[Modified by iwouldHITit, 1:25 PM 2/16/2003]
CRXguy_88
Jul 11, 2010 09:10 PM
ExVtec
Oct 16, 2008 10:48 PM
stocker2shocker91
Dec 22, 2006 02:22 PM
juicy.koreans.suck
Mar 7, 2002 12:08 PM
