Synchro?
Old Feb 15, 2003 | 01:22 PM
eight grand's Avatar
Default Synchro?
ok my car grinds going into 3rd at high rpm. i think its my synchro but i dont know. if it is were can i get one and how mouch are they.
Old Feb 15, 2003 | 01:37 PM
tegasaurus's Avatar
Default Re: Synchro? (eight grand)
regardless of model, it'll be 211 bucks for a new gear set from acuraautomotiveparts.org
[Modified by tegasaurus, 3:40 PM 2/15/2003]
Old Feb 15, 2003 | 03:43 PM
Default Re: Synchro? (tegasaurus)
some one told me i could get the synchro seperatly instead of buying the set.
Old Feb 16, 2003 | 06:08 PM
bump
Old Feb 16, 2003 | 07:33 PM
TeamTooQuick's Avatar
You can buy the synchro set, which if I remember right 3rd and 4th share the same synchro. But you can buy the synchro separate....
Edit: I had the same problem a little while ago and I just bought all the gear set with the synchros and everything. And if i was you i would get the bearings and seals to while you have the tranny open, just my .02 cents...
[Modified by TeamTooQuick, 4:34 AM 2/17/2003]
Old Feb 20, 2003 | 02:29 PM
Default Re: Synchro? (TeamTooQuick)
bump
Old Feb 20, 2003 | 04:05 PM
ATYPR's Avatar
Try GM sycromesh trans fluid first. I just fixed 2 of our cars.
Old Feb 22, 2003 | 02:24 PM
Default Re: Synchro? (FUCATYPR)
whats that? and where do you get it and do you just put in the with transmission...
Old Feb 22, 2003 | 02:33 PM
IC x Prince's Avatar
New User
it's tranny fluid
Old Feb 22, 2003 | 04:25 PM
aznmc16's Avatar
the gear set... is that the COMPLETE SET?? cuz im grinding alot.
Old Feb 22, 2003 | 08:15 PM
Default Re: Synchro? (aznmc16)
if i put just the just the synchro i need will it wear out the parts in the tranny because its new...
Old Feb 23, 2003 | 05:10 AM
New User
i don't think so, but if it's not bad, or you don't have alot of money, you can just replace the synchro...but if it's bad, then you might have to replace the gear set...
Old Feb 23, 2003 | 06:37 AM
GS-Rcivic's Avatar
Default Re: Synchro? (UltraPrince)
is it possible to get the final drive diffrerent , say the typeR one, when purchasing the gear set? mine grinds second (mostly) and third. i go from first to third and it sucks not being able to use the best gear.
how much does the labor cost after you get the gear set?? any help will be good help. thanks.
PS: i didnt mean to steal your post here
Old Feb 23, 2003 | 08:17 AM
Muckman's Avatar
Moderator in Chief
How much did you spent on all the parts you replaced?
I have the same problem after 3 years of abuse... my 3rd gear grinds when being shifted into at high RPM or shifted quick. I want to get my tranny rebuilt before I go turbo.
Old Feb 23, 2003 | 05:09 PM
Default Re: Synchro? (Muckman)
so can i change just the one synchro that i need...
Old Feb 23, 2003 | 05:54 PM
Muckman's Avatar
Moderator in Chief
I inquired Acura about this. They only sell the synchros as an entire forward set. But the synchro set itself wasnt that expensive. I recall it was around $200+/- for the set. Im not sure what else youd need to replace to support the synchros tho.
Its a big job tho. Alot of labor.
Old Feb 26, 2003 | 01:08 PM
bump...
Old Mar 6, 2003 | 06:19 AM
bump
Old Mar 6, 2003 | 06:27 AM
New User
why did you bump? the answer is there. if you are going to replace the synchro replace the gears that come with it...all problems solved wether it was the synchro or the gears..it all got replaced. are you looking for th magical fre diy fix...i 'm sure we all like to see that...we all have the same problem.
Old Mar 6, 2003 | 10:27 AM
Aero Deck's Avatar
Ive got the same problem with my LS on 3rd and 4th. It is the synchro and when you go to the dealer to get it you will find out that you cant just buy the synchro ring but you have to buy it along with the hub bearing and another bearing. $280 per gear.
Old Mar 6, 2003 | 10:55 AM
JeremyL's Avatar
Default Re: Synchro? (DAsicks)
could i get the 2 3 4 from a GSR or TypeR and drop them right into my LS tranny and keep my nice LS final drive
Old Mar 6, 2003 | 12:03 PM
New User
Default Re: Synchro? (JeremyL)
yes you can
Old Mar 6, 2003 | 05:22 PM
JeremyL's Avatar
so when i have my tranny rebuilt i just buy an LS 1 and 5, 99-00 Si 2,3,4 cuz im sure a civic si part would be cheaper than a TypeR part. now can i just drop in a TypeR lsd and still keep my LS final drive? also is the 5th gear the final drive or is the final drive a seperate piece
basically i want to custom build the ultimate tranny and i think having a taller 1st with a really tight 2,3,4 is a good combo and since i do a lot of hiwy driving i definitely want the LS 5th
Old Mar 7, 2003 | 05:33 PM
Ruby Civic's Avatar
Good topic.
What about JDM b16 (s1) trannies that have so many probs. with the 3rd gear synchro - would that be GSR, etc. replacement too or diff application, or impossible??
Old Mar 7, 2003 | 06:18 PM
ACURATSX's Avatar
new Synchro is about $160
