question about 5th gens
In my 97 Accord, while i'm at a light, or just stopped and i have my AC on, is it supposed to somewhat vibrate every minute or so? It just starts to shake then stops. Anyone else seen this happen before?
Thanks
Thanks
Every time the compressor kicks in, the engine speed drops momentarily as the load on the engine increases. There is a vacuum servo which increases the throttle opening when this happens, adjusting the idle back to the correct RPM.
This can also happen when your radiator fans switch on.. the ELD (Electric Load Detector) increases the idle to compensate the extra load when you have switch on the A/C
LONO100
Feb 1, 2012 08:13 PM
361 accord
Nov 15, 2009 12:19 PM
