car wont start? havent had this problem before need some help?
Old Feb 15, 2003 | 11:18 AM
sharkey65a's Avatar
Default car wont start? havent had this problem before need some help?
i just changed my oil and went to start it up to check for leaks and **** and the ignition wont even turn? ive never had a probem with the ignition before. it is like negitive 15 outside so i was expecting some risistance but why wont the ignition even turn. tahnks
... Alex
Old Feb 15, 2003 | 11:34 AM
M-Type's Avatar
Default Re: car wont start? havent had this problem before need some help? (sharkey65a)
sometimes you have a dead spot on your alternator and have a hard time starting the car. This is normal due to wear and tear.
Old Feb 15, 2003 | 01:45 PM
ernald711's Avatar
i had this problem before... it started of by me pushing the button for my alarm, but wouldn't work. i figured my alarm key needed a new battery, so i juss opened my car the old fashion way, with the key. i got into the car and tried to start it. it wouldn't start, i figured the car's battery was drained cause i also tried to use the power locks and i got no response. anyways, i have a poorly bolted on MSD SCI ignition, and when i popped the hood, it was hanging loose. I guess it got ground'd out. I juss had to jump start the car and fix the whack bolting. I never had the problem again... meaning to say that something might be grounding out your system. a poorly wired stereo or amp, that's wired to always be on could also be a problem. i had a friend with this problem. i hope find what the problem is, cause what the use of fix'n up your ride for more HP and TQ if it won't even start.
Old Feb 15, 2003 | 01:51 PM
2k1_ITR_0736's Avatar
Default Re: car wont start? havent had this problem before need some help? (ernald711)
yeah, always check the grounding.
hey man, nice signature.....
Old Feb 15, 2003 | 02:00 PM
sharkey65a's Avatar
Default Re: car wont start? havent had this problem before need some help? (2k1_ITR_0736)
the problem is definitly not the battery or the alternator because the key wont even turn!?
....... i figured it out. thanks for your help
[Modified by sharkey65a, 11:23 PM 2/15/2003]
Old Feb 15, 2003 | 02:29 PM
94TealGSR's Avatar
haha, was your steering wheel locked by chance?
Old Feb 15, 2003 | 03:53 PM
M-Type's Avatar
Default Re: car wont start? havent had this problem before need some help? (94TealGSR)
HAHA YEA is it locked?
this_guy07
Nov 14, 2008 03:11 PM
donut.
31
Jan 28, 2008 11:38 AM
nY's FiNeSt
10
Mar 3, 2004 05:02 PM
92TEGsrSC
Jun 18, 2003 09:15 PM
Randomlude
Oct 7, 2002 09:47 PM
