power windows?
Just curiouse if anyone has put these on a 97 civic hatch? does anyone have instructions on how to do it?
I searched but came up with 2 topics and No instructions
Thanks in advance
[Modified by ITRacer121, 5:38 PM 2/15/2003]
Thanks in advance
i put some spal power windows in my EK...the only help that i got was from a Helms manual, since i was using SI switches and panels. the spal kit has two wires, one for up and one for down...connect it to the wires from the SI switch, along with the power and ground on the SI switch and it should be good....get a Helms manual, they help a lot....any more questions?
I just put power windows in my EG, I'd image it'd be similar. The windows I used were JDM so wiring was a so the left switch on the master switch would control the left window. PM me if you think I could help.
-Jake
-Jake
i didn't put in a relay for my power windows, however for the wire that taps for power, i put in a 20amp fuse, and they will occasionally blow if i put too much load on the power windows.
[Modified by Airbag Club, 9:09 PM 3/9/2003]
i have power windows and locks in my 97 hatch out of a 98 ex. you must've not searched hard enough, because there were some pretty detailed instructions before. its pretty straight forward. get the motors and wiring out of the doors, wiring from underneath the carpet, and swap them. you can figure out the little details on your own pretty easily.
Danny89
Mar 15, 2013 03:41 AM
