vtec not working
my friend just finished installing his B16a1 into his 91 civic si, vtec was not weird up right because the guy that did the install is not an import guy, does anyone have a diagram of what wires from the b16 motor harness and the stock harness inside go to gether???
wire as follows:
vtec solenoid goes to A8
vtec oil pressure goes to B5
knock sensor goes to B19
2nd O2 sesnsor goes to C8
good luck!
44 is what it was stock and that day it was 46 i didn't change it. maybe the regulator bolt moved byitself. i didn't have the jam nut tightened down cause i thought that i would change it later.
ahc'monracing
Jun 8, 2004 06:06 PM
freeeked
Aug 30, 2003 02:27 AM
