Anyone have pics of the Z10 engineering traction control system
Lip,
Have you tested out the Z10 on the track ? Does really help prevent axles and CV joint breakage from high RPM launches(6500-7500+) ?
Also, wouldn't you by chance have any recommendation for stronger axles ? So, far I think I might get the driveshaftsshop stage 1 kit, and see if that will hold up to launches around that RPM ? I put down around 175hp and 132 lbs, do think that driveshaftshop stage axles can hold up to that type of launches ?
I don't think a Type R will need this. It strenghtens the front lower arm assembly....
For more info please see the article on HYBRID.
Http://hybrid.honda-perf.org
Titled Z10 Radius Arms
If you have any questions feel free to email me at geoff@z10eng.com or call us at 732-922-2309.
A type R will surely benefit from the addition of lower control arm stabilization.
James
With my personal car, a turbo 94 civic hybrid, i have hit a best of 1.97 60 foot with BFG drag radials. With a 555r drag radial 2.06 was the best.
The best thing the traction bars do is that they truly stop, *any* wheelhop. For all street racers out there that bounce like a rabbit outta the hole, this makes a world of difference. Street tires really allow the arms to work. The wrinkle walls of a slick diminsh wheelhop as they absorb shock, making radius rods effects less noticable.
havent read any of the mentioned articles yet...but is this a drag racing only application? will it help any in an autocross or roadcoarse, other than starts?
This is not at all a drag race only product. We have a number of road racers that use our kit, and none of their cars will ever see the drag strip.
Read the hybrid article, as Joe R (webmaster at hybrid) is not at all a drag guy, and very much into handling. Deflection of the lower control arms is completely minimized and caster can now be adjusted via preload tension. I hope this helps.
