Just got camera back...Pics of Benen lower tie and DIY trunk bar
Old Feb 14, 2003 | 12:59 PM
01SilverGSR's Avatar
Default Just got camera back...Pics of Benen lower tie and DIY trunk bar
These two mods made a huge difference in how the car handles. The back end feels so much more planted to the ground. The only bad side is now it feels like the front end needs some stiffening, but I have to decide between the Benen 3-point front strut bar and the Neuspeed one. Also I had to use a lot of washers as spacers to get the Benen bar to fit over the ITR sway bar bushing bracket. Anyone else had that problem? Well here are the pics, tell me what you guys think.
Just for laughs I threw in a pic of the car I drove before Teg!!
Hell yeah, 1984 Oldsmobile Delta 88 with an Edelbrock carb and Flowmaster dual exhaust. Boy was that a difference when I got the Teg!!
Old Feb 14, 2003 | 01:23 PM
Brandon Chun's Avatar
Default Re: Just got camera back...Pics of Benen lower tie and DIY trunk bar (01SilverGSR)
I like that Benen tie bar, if you don't mind how much was it? My main concern with a tie bar was how much of a pain would it be with my itr r sway bar, so I never ended up getting one. Like the trunk bar too
Old Feb 14, 2003 | 01:40 PM
Default Re: Just got camera back...Pics of Benen lower tie and DIY trunk bar (Brandon Chun)
I got the Benen from a local speed shop for $129. IMO the Benen bar is worth the money and the hassel of installing it.
Old Feb 14, 2003 | 01:45 PM
Understeer's Avatar
Nice!
I like my DIY trunk bar also.
How do you lay the trunk board with the trunk bar in place?
Old Feb 14, 2003 | 01:47 PM
tC_Dragon's Avatar
looks real good, i think alot of people have alot of problems with mounting a tie bar that will work with different sway bars... thats y i kinda like the comptech combo, but benen definitely has some really nice products. I doubt that teh washer trick will have any negative affect, but you may want to consider going to a hardware store and purchasing one of those metal spaces that looks like a thick *** washer and use that instead of a whole bunch of little washers. my .02
Old Feb 14, 2003 | 02:48 PM
Default Re: Just got camera back...Pics of Benen lower tie and DIY trunk bar (Understeer)
Nice!
Right on top
Old Feb 14, 2003 | 02:55 PM
Jolf's Avatar
Nice, had I not just spent a bunch of money on tires I'd pick up a rear tie bar also.
You know those wheel locks do you no good in the trunk right?
Tim
Old Feb 14, 2003 | 05:41 PM
wuhungsixxx's Avatar
New User
first time iv seen the Benen before...i like!
Old Feb 14, 2003 | 06:59 PM
airon's Avatar
same setup as me that i am installing this weekend! (if weather permits)
do you have any issues with take your spare out with the trunk bar?
Old Feb 14, 2003 | 07:28 PM
au-gsr's Avatar
Default Re: Just got camera back...Pics of Benen lower tie and DIY trunk bar (airon)
that other car looks like what cam out of your *** yesterday!!
Old Feb 14, 2003 | 07:55 PM
stumpyf4's Avatar
Default Re: Just got camera back...Pics of Benen lower tie and DIY trunk bar (au-gsr)
Looks like a nice set-up. I'll be doing a rear Comptech Tiebar ($200 without the swaybar, cross your fingers it's in the mail) and ITR sway bar along with a ITR trunk bar in the spring (both sitting under my bed). Should be sweet!!
Old Feb 14, 2003 | 08:45 PM
Default Re: Just got camera back...Pics of Benen lower tie and DIY trunk bar (Jolf)
Tim
Haha....Those are just the spare lug nuts from using the wheel locks.
airon:
It's actually almost impossible to get my spare tire out. Since my sub box is screwed down to metal the cardboard doesn't bend any further then in the second pic. To take that pic I was using all my strength to hold it up without cracking it. Basically if I ever get a flat, Acura Roadside Assistance to the rescue or spend 45min trying to unscrew that damn box. But I don't believe the trunk bar will affect getting the spare out at all. You would just have to angle it a different way.
[Modified by 01SilverGSR, 12:46 AM 2/15/2003]
Old Feb 14, 2003 | 08:51 PM
Hey don't diss the Olds that bad man....I restored that thing during high school and worked on it like every other weekend to keep it running. It has a 5.0 liter v8, whiched averaged 10mpg. Damn, a car with torque, who would think
Old Feb 14, 2003 | 09:05 PM
Understeer's Avatar
An easier alternative is to the have a socket wrench handy in your car at all times, if you ever need to remove your spare tire easier.
Old Feb 14, 2003 | 09:12 PM
Yeah true....but what I'm actually going to do is some time, either during spring break or during the summer, I'm going to take out the cardboard floor and replace it with plywood cut to fit the trunk and with hinges infront of the sub so I can just fold up the wood to get to my tire. Also I would make a cut out for the trunk bar to the wood would lie flat. I just have to get the time to tackle this project. Right now school is OWNING me!!
Old Feb 14, 2003 | 09:24 PM
Understeer's Avatar
That is an excellent idea.
I trimmed the board so that it fits under the trunk bar. However it takes a lot of effort to get it under, and is next to impossible to remove.
So, I am going to tackle this project in the next week with your idea of the hinges.
Home Depot OWN3Z.
Old Feb 14, 2003 | 10:37 PM
Bewkrazed's Avatar
hey wen u used the washers did u get a longer bolt or you just used the sotck bolt to make the lower tie bar fit?? i have the same problem right now.
Old Feb 14, 2003 | 10:52 PM
conesmasher's Avatar
Default Re: Just got camera back...Pics of Benen lower tie and DIY trunk bar (Bewkrazed)
That bar looks really good, nice job, anyone have any probs with installing it with a Sus. Tech rear sway 19mm
Old Feb 15, 2003 | 03:02 PM
Actually the Benen came with new longer bolts so I just used those. They probably could be a little longer but they should be fine. I just torqued the hell out of them.
Old Feb 15, 2003 | 06:57 PM
Bewkrazed's Avatar
okay. how many washers did you use??
Old Feb 15, 2003 | 09:02 PM
I used probably 8 or 9 fender washers on each side. And with that many, the bar still probably touches the bottom bolt for the sway bar bushing bracket.
Old Feb 15, 2003 | 09:18 PM
SonicGSR's Avatar
Digging the Olds
Old Feb 23, 2003 | 04:50 AM
integra-modder's Avatar
Default Re: Just got camera back...Pics of Benen lower tie and DIY trunk bar (SonicGSR)
Old Feb 23, 2003 | 06:00 AM
2k1_ITR_0736's Avatar
Default Re: Just got camera back...Pics of Benen lower tie and DIY trunk bar (integra-modder)
Old Feb 23, 2003 | 09:41 AM
Default Re: Just got camera back...Pics of Benen lower tie and DIY trunk bar (2k1_ITR_0736)
if you can see **** but can use HT, id see a doctor of I were you...
we-todd-did hosting is down again
