Having TPS and Map sensor problems, Y8
Old Feb 14, 2003 | 12:41 PM
CimorelliCRX's Avatar
Default Having TPS and Map sensor problems, Y8
Okay now im gonna try to go as in depth as I can here. Me and a freind just rebuild a D16Y8, it had spun bearings, so I rebuilt it with everything new, and machined, etc. Not that all that matters.
But the problem is when we were pulling the motor it swung back and broke the TPS sensor, so we took a TPS sensor off one of the A6 throttle bodies we have. amd put it on the Z6 throttle body. We are using a Z6 intake manifold.
What happens is when you rev it, slow its fine, under hard acceleration it bogs down. Now to me it sounds like a TPS problem. But I dont know if its because I am using a SI TPS on a Z6 throttle body(i do not see hwo that would affect it). Or what.
We are also using the map sensor on the throttle body.
Anyone have any ideas?
Old Feb 14, 2003 | 01:14 PM
Default Re: Having TPS and Map sensor problems, Y8 (CimorelliCRX)
ttt
Old Feb 14, 2003 | 02:02 PM
Wes d's Avatar
Probe the red wire on the tps with a volt meter, key on, and check the voltage. It should be set around .45 closed and about 4 volts wot.
Old Feb 14, 2003 | 04:43 PM
SiR831's Avatar
Default Re: Having TPS and Map sensor problems, Y8 (Wes d)
Did the wires come out of the TPS connector? If so maybe the 2 outter wires are crossed?
Old Feb 14, 2003 | 09:14 PM
crxhfpower123's Avatar
Default Re: Having TPS and Map sensor problems, Y8 (SiR831)
ttt
SiR eF_4door
11
Aug 9, 2009 03:35 PM
tico
Oct 3, 2008 11:39 AM
CimorelliCRX
May 14, 2003 09:38 AM
MetalKill
Apr 30, 2003 09:51 PM
arren123
Jan 18, 2002 07:36 PM
