Anyone have a problem w/ their sway bar endlinks coming out? I do.
Old Feb 14, 2003 | 12:06 PM
ichibano's Avatar
Default Anyone have a problem w/ their sway bar endlinks coming out? I do.
I have a Type-r rear sway bar w/ Si endlinks. One of the enlinks keeps coming out, the one that connects to the sway bar. I was thinking maybe I installed the bar upside down. Anyone have pics of a type-r sway bar on an EK. Thanks, in advance.
Old Feb 14, 2003 | 12:09 PM
tonyxcom's Avatar
Default Re: Anyone have a problem w/ their sway bar endlinks coming out? I do. (ichibano)
are you using a Beaks Kit? If not, get one.
Old Feb 14, 2003 | 01:29 PM
ichibano's Avatar
Default Re: Anyone have a problem w/ their sway bar endlinks coming out? I do. (tonyXcom)
I have the BSQ kit.
Old Feb 14, 2003 | 01:55 PM
ATS*Mark's Avatar
OG triple OG
whats a BSQ kit , and you prolly installed the endlinks backwards.
Old Feb 14, 2003 | 02:01 PM
ichibano's Avatar
Default Re: Anyone have a problem w/ their sway bar endlinks coming out? I do. (TURSpoonEK)
The BSQ kit is a subrame reinforcement. Which way should the nut on the endlink face? outwrds or inwards?
Old Feb 14, 2003 | 02:02 PM
tonyxcom's Avatar
you cant install endlinks backwards.
The SI endlinks fit LOOSE in an ITR rear sway bar. I am not sure what the ESQ kit comes with but the beaks kit comes with solid bushing you put in the sway bar so that the SI endlinks fit snug and can't worm out.
Old Feb 14, 2003 | 02:22 PM
greebler's Avatar
Beaks endlinks
Old Feb 14, 2003 | 02:36 PM
cre18's Avatar
Default Re: Anyone have a problem w/ their sway bar endlinks coming out? I do. (greebler)
use a washer in between your sway bar and nut, it may help to hold your endlink on.
Old Feb 14, 2003 | 02:43 PM
fowler!'s Avatar
Default Re: Anyone have a problem w/ their sway bar endlinks coming out? I do. (cre18)
Wil uses washers that are a specific size. If you get them too big, the nut won't thread on.
Old Feb 14, 2003 | 02:51 PM
cre18's Avatar
Default Re: Anyone have a problem w/ their sway bar endlinks coming out? I do. (fowler)
right, mine fell off once and i lost both the nut and washer . emailed Wil and he sent me a couple replacements
props to Wil and Beaks kit
Old Feb 14, 2003 | 02:55 PM
ichibano's Avatar
What if I use a regular 3/8's washer and use loctite or nyloc on the nut? That should hold.
Old Feb 14, 2003 | 02:56 PM
fowler!'s Avatar
Yup. Wil did the same thing for me. Super good customer service.
r1ch1e
Oct 14, 2006 06:42 AM
spikerockz
Nov 10, 2005 08:06 AM
Kev95lx
Sep 26, 2003 05:54 AM
MAD ITR 55
Jul 10, 2003 03:02 PM
dgdarien
10
Mar 30, 2003 01:09 PM
