NGK BKR7E or BKR6E plugs?
Old Feb 14, 2003 | 10:22 AM
T_Rex's Avatar
Default NGK BKR7E or BKR6E plugs?
I'm using the BKR7E-11 in my B16A, but I read where many people are using the 6Es. Are the 7Es colder? What do you guys suggest? Which one would be the best for my engine?
Old Feb 14, 2003 | 12:20 PM
T_Rex's Avatar
Default Re: NGK BKR7E or BKR6E plugs? (T_Rex)
NE1?
Old Feb 14, 2003 | 01:12 PM
Gorm's Avatar
the 7's are a colder plug. If you are running nitrous or boosting go with the 7's. If you are N/A then it wont matter much which plug you use, but I'd probably use the 6's since they will be easier to find.
Gary
Old Feb 14, 2003 | 01:40 PM
T_Rex's Avatar
Default Re: NGK BKR7E or BKR6E plugs? (Gorm)
It's a stock B16A with I/H/E...no internal mods or nitrous. Will a colder plug hurt performance in any way or will it just shorten the life of the plugs?
Old Feb 14, 2003 | 03:30 PM
T_Rex's Avatar
I found this on the NGK site:
Let's make this really simple: when you need your engine to run a little cooler, run a colder plug. When you need your engine to run a little hotter, run a hotter spark plug. However, NGK strongly cautions people that going to a hotter spark plug can sometimes mask a serious symptom of another problem that can lead to engine damage. Be very careful with heat ranges. Seek professional guidance if you are unsure.
With modified engines (those engines that have increased their compression) more heat is a by-product of the added power that normally comes with increased compression. In short, select one heat range colder for every 75-100 hp you add, or when you significantly raise compression. Also remember to retard the timing a little and to increase fuel enrichment and octane. These tips are critical when adding forced induction (turbos, superchargers or nitrous kits), and failure to address ALL of these areas will virtually guarantee engine damage.
An engine that has poor oil control can sometimes mask the symptom temporarily by running a slightly hotter spark plug. While this is a "Band-Aid" approach, it is one of the only examples of when and why one would select a hotter spark plug.
This makes me thinks that the 7E is too cold for a NA engine. Agree???
Old Feb 15, 2003 | 08:51 AM
Gorm's Avatar
the only thing that running a colder plug on an old engine could happen is the plug might oil foul. If it were me I would run the 6 series plug. I really dont think you'll see much performance difference in the two plug, N/A. The reason for running a colder plug is to lessen the chance of detonation and that happens mostly in boosted or nitrous applications.
Old Feb 15, 2003 | 06:41 PM
T_Rex's Avatar
Thanks, Gorm.
Anyone else? Feel free to chime in anytime
mugen94
Aug 19, 2009 04:22 PM
7rrivera7
Sep 30, 2003 12:55 PM
TeamTooQuick
Aug 9, 2003 07:23 PM
T.J.
Feb 20, 2003 06:33 AM
