Differences between CLutch disc size?
Old Feb 13, 2003 | 04:54 PM
Toptul_Honda's Avatar
New User
Default Differences between CLutch disc size?
I have an 88 Tranny using the 90+ flywheel/presure plate set up.
Does it matter about which size to use? 190mm or 212mm?
will disc life, grabbing power be affected by which size i use? i need to know
Old Feb 13, 2003 | 05:03 PM
slomofo's Avatar
GDD Member
Default Re: Differences between CLutch disc size? (G2-Rex)
I don't know the answer to your question but if a clutch disk is too large, it might not fit inside the pressure plate.
Old Feb 13, 2003 | 11:52 PM
New User
Default Re: Differences between CLutch disc size? (slomofo)
up
Old Feb 15, 2003 | 01:18 AM
New User
just picked up a 86-89 ACcord exedy clutch disc for my 90-91 crx Pressure plate and oem lightened flywheel
[Modified by G2-Rex, 12:47 AM 2/16/2003]
Old Feb 15, 2003 | 09:39 AM
Malgerus's Avatar
hmm kinda confused. I know if you're using 88 tranny u need an 88 clutch.
Old Feb 15, 2003 | 10:48 AM
theclutchpoppa's Avatar
Default Re: Differences between CLutch disc size? (Mr. S)
i just did this on my CRX i got the ACT 212mm upgrade and i use the 90 flywheel on my 88 trans
Old Feb 15, 2003 | 11:48 PM
New User
Default Re: Differences between CLutch disc size? (theclutchpoppa)
yeah im going to use a 212mm 21 spline 86-89 clutch disc on my 90+ pressure plate and lightened flywheel
i hope it grabs better than the 88 disc
90_EX_Civic
Mar 1, 2010 07:02 AM
vtec-adykt
Nov 16, 2006 06:45 PM
PaImportTuner
11
Jan 16, 2004 09:49 AM
memphiss13
Feb 7, 2003 02:33 PM
