Clicking sound from Wheel area (Not Axel)
Old Feb 13, 2003 | 04:28 PM
ace1875's Avatar
Default Clicking sound from Wheel area (Not Axel)
Ok couple of weeks back my axel went bad so I waited till this weekend to replace it. Still after i did i hear a clicking sound when ever i release the clucth, in a way that the car jerks when the clucth is released, I can hear the driver side wheel area clicking for a short time then goes away.
My axel is not bad cause when i turn i don't hear anything.
Any Ideas of what that might be?
I checked everything and all the bolts are on tight.
Old Feb 13, 2003 | 04:53 PM
ace1875's Avatar
Default Re: Clicking sound from Wheel area (ace1875)
anyone?
Old Feb 13, 2003 | 05:31 PM
tominos's Avatar
wheel bearing?
Old Feb 13, 2003 | 05:33 PM
ace1875's Avatar
Default Re: Clicking sound from Wheel area (tominos)
do they sound only on a jerk?
Old Feb 13, 2003 | 05:50 PM
Tetsuwan Atomu's Avatar
yea wheel bearing or cv joint area might be bad....
[Modified by Tetsuwan Atomu, 6:55 PM 2/13/2003]
Old Feb 13, 2003 | 06:01 PM
romeo619's Avatar
Default Re: Clicking sound from Wheel area (Tetsuwan Atomu)
sometimes when abs goes bad you will hear a ticking sound
Old Feb 13, 2003 | 06:11 PM
ace1875's Avatar
Default Re: Clicking sound from Wheel area (romeo619)
don't have ABS
What do you mean by CV Joint area?
Old Feb 13, 2003 | 06:15 PM
Damon's Avatar
my car does this too...I know that I have a blown left front shock...I think it might be from extra slack between the spring and the perch...email me and I will get back to you after I get a new shock and let you know if a new shock solved the probem.
-Damon
dfisher72@houston.rr.com
Old Feb 13, 2003 | 09:20 PM
hondasleeper's Avatar
Default Re: Clicking sound from Wheel area (Damon)
My car just started doing the same thing. It's a worn axle. It does that when I brake hard and when I move off. Did the steering lock and drove in a circle, no clicking when I did that, CVs are ok. I'm gonna change out the passanger axle, will let you know if that solved the strange clicking sound.
Old Feb 15, 2003 | 06:39 PM
ace1875's Avatar
Default Re: Clicking sound from Wheel area (hondasleeper)
no bro I already changed my axels and its still doin it. Its even worse in Rain
Old Feb 15, 2003 | 07:14 PM
KURRRRWA
Guest
Posts: n/a
I'm guessing the bearing inside the CV boot.
Are you sure it's good?
Old Feb 16, 2003 | 10:54 AM
DCStreetHtch's Avatar
Default Re: Clicking sound from Wheel area (KURRRRWA)
cv joint... i'll put money on it.
-Bryan-
DsevenEm2
Honda Civic (2001 - 2005)
Oct 13, 2007 12:04 AM
paz9x
Jan 26, 2006 10:11 AM
Liquidgsr
Jan 15, 2006 09:11 PM
Type-R 940
Mar 25, 2004 06:41 AM
