coilovers or springs...
I got a gs-r and right know its sitting on neuspeed springs but the car is too low. it hits every speed bump and every bump on the road..should i get some coilovers or some springs for it?...and how much would they each cost to get them put on
[Modified by CivicSiR94, 11:16 PM 2/13/2003]
depends on if you want it for looks or preformence. Go with good coil overs like teins for preformance. If you just want your car higher get better springs
You can get a set of Ground Control Coils for about $300 (adjustable), or a set of like Eibach Pro-kit Springs for around $200 (1.3" drop about). Either way they will get your car to sit higher, usually shops will put them on for around $100 depending on where you live.
