How hard to install a turbo kit on a 4th gen?
Old Feb 13, 2003 | 01:19 PM
lildrgn2.0's Avatar
New User
Default How hard to install a turbo kit on a 4th gen?
the works????? Turbo, IC, new radiator, hondata, gauges, everything..
how hard and how long for 3 people to accomplish??
weekend?... maybe?
and is the FMAX kit anygood?
[Modified by Lildrgn Half EVIL, 4:19 PM 2/13/2003]
Old Feb 13, 2003 | 02:00 PM
Firedrake's Avatar
Default Re: How hard to install a turbo kit on a 4th gen? (Lildrgn Half EVIL)
If everything is bolt-up, you have access to a lift and good tools, and you don't need to do any crazy modifications, I'd say you could do it in a weekend easy.....tap accessory on for the gauges off the back of the cigarette lighter.....tough part is wiring them into the lights, I forget which wire is the one to use....
If you have to start doing custom stuff and modifying things, expect it to take a LOT longer....
The FMAX kit is OK, better than the drag kit at least.....I'm all about custom personally.....remember you'll need to reroute the power steering cooler lines if you're using the FMAX kit, so have some extra power steering fluid handy as well as a couple feet of hose......
And don't use the MF2 (you have hondata, so I assume you have bigger injectors?).......and as always the oil return is going to be a bitch......
Brian
Old Feb 13, 2003 | 04:14 PM
Shakes's Avatar
space cadet
Default Re: How hard to install a turbo kit on a 4th gen? (Firedrake)
when i talked to a few of the guys around here they were saying that they had to loose the ac. so account for the removal of that while you are at it.
Doug
Old Feb 13, 2003 | 05:20 PM
lildrgn2.0's Avatar
New User
Brian
I dont have a Hondata yet.. I am working on that when i get the turbo kit..
along with injectors..
Old Feb 14, 2003 | 10:42 AM
lildrgn2.0's Avatar
New User
I wont need bigger injectors if I stay around 6-8 psi will i?
Old Feb 14, 2003 | 11:11 AM
apexii's Avatar
Default Re: How hard to install a turbo kit on a 4th gen? (shakes)
Doug
I have to concur. I did my install more than once, and i'm positive that a/c does not need to be messed with.
I removed my a/c but for other reasons
Old Feb 14, 2003 | 12:19 PM
Shakes's Avatar
space cadet
Default Re: How hard to install a turbo kit on a 4th gen? (apexii)
i stand corrected then. i will have to see what they were talking about then.
Doug
Old Feb 14, 2003 | 01:15 PM
Johnnytech's Avatar
When I installed the FMAX kit on my 96 I had to modify a high pressure a/c sensor in order to get thr FMIC to fit correctly.
Old Feb 14, 2003 | 07:18 PM
Firedrake's Avatar
Default Re: How hard to install a turbo kit on a 4th gen? (Johnnytech)
The one right below the canister (a/c evap dryer or whatever it's called) right? My FMIC sits right on it, but doesn't seem to have any problems...
Brian
Old Feb 17, 2003 | 04:08 PM
Johnnytech's Avatar
Yes that it the one, just in front of the radiator. My FMIC was pushed up against it and the mounting hole wasn't even lined up. I Cut the plastic on the sensor, soldiered wires to it, sealed it with silicon then connected my wires to the plug. Now there is lost of room.
Old Feb 17, 2003 | 05:16 PM
BoostedH23a1's Avatar
i did all mine in about 6 hrs. but i have air tools and a lift.
Old Feb 17, 2003 | 09:23 PM
Kaizen's Avatar
Default Re: How hard to install a turbo kit on a 4th gen? (BoostedH23a1)
Yeah, without access to the right kind of tools, installation can take forever. I think the harder part isn't the turbo, it's any motor work you get done to prep for the turbo. Nobody likes pulling out prelude motors... they're so big & heavy (in comparison to B-series).
But yeah, the actual turbo installation, my friend's shop finished it in 2 days, and that's while working on other customer's cars too. Oh yeah, and tuning it will take some time cuz you gotta make lots of "test runs".
Old Feb 17, 2003 | 09:24 PM
Kaizen's Avatar
Default Re: How hard to install a turbo kit on a 4th gen? (Kaizen)
One more thing, I don't know about other people, but I had to get my reinforcement bar cut slimmer to fit the intercooler. Obviously it would help if you had the right tools.
Old Feb 17, 2003 | 09:31 PM
PrecisionH23a's Avatar
no you wont, with 3 people i say you can knock the actual install out in a day with the right tools. 2 days tops in case you run into any problems.
Old Feb 17, 2003 | 10:41 PM
Quiklude's Avatar
Default Re: How hard to install a turbo kit on a 4th gen? (GudeH23a)
mine wasnt that bad took 2 days just me, and i did a new clutch while i did that. im running f-max.......its a decent kit, definately better than the DRAG but Custom kits are the way to go. But im lazy and dont want to mess with fabricating stuff, it takes away from my time
ridnmyhonda
Mar 11, 2003 05:05 PM
hondAC
Dec 7, 2002 07:40 PM
canyoutypeR
Nov 9, 2002 09:11 PM
wicx
Jun 3, 2002 04:55 PM
