kyb agx vs kyb gr-2
For the most part, the GR-2 is basically a OEM replacement shock, the AGX is more of a performance shock that would be better suited for aftermarket springs.
I've seen AGX's for ~300, so that's only $25 more per shock.
I have sportlines right now, intending to get KYB AGX's soon. anyhow, is it possible for me to adjust the ride height (since eibach drop is somewhat uneven as most of you already know)?
oh screw it ill just get TypeR springs, all this crap i hear about uneven aftermarket srpings and too low springs that drop your car too much blah
would the GR2's be a good match to the ITR springs? I dont really see myself autoX'ing the car but I want it to be better than stock. of course after 227K even new LS replacement stuff would be better than now lol
[Modified by JeremyL, 5:20 PM 2/13/2003]
what would be a good spring to use with the AGX? I really dont want to lower more than 1.5" at the absolute most nor do i want to max out the damper
I'm currently running with AGXs. Personally, I think they're great struts. I also have Eibach sportlines. I hear you shouldn't go any lower than 2" with these struts and I also heard that even my 1.8" sportlines are kind of pushing it.
If you don't plan on going too low, I think the AGXs will be great for you.
I'm gonna be upgrading to Koni yellows later so I can lower my car more with H&R race springs.
Good luck.
Good luck.
... also try the h&r sport spring .. should complement w/ the shock ... i have kyb agx but w/ coilovers, so i can adjust the height ...
