Trunk mount battery...
I ordered the battery mount kit and should have a new battery soon. Where exactly is everyone else putting the battery, in the pass. corner on that small flat of metal or behind the pass. seat. Any pic's of the job with options on the power lead path from the engine bay would be very helpfull
Thanks
Thanks
Well when I had my B16A swap I had it placed in the right corner of my trunk. Also I used a marina battery casing so that I could vent all the battery gases out of the car. If your doing this yourself then remember to run the power line to front but run the ground to frame of the car closer to the battery.
The battery is a spiral gel cel and I bought a trunk mount kit from Summit which inlcudes everything you need for install including box for like 43.00 or something. thanks for the info
pendejon
Feb 23, 2006 12:52 PM
GARBhatch.
Oct 7, 2002 11:08 AM
