OBDI conversion makes car run irregular??????
Old Feb 12, 2003 | 08:56 PM
EuRoBrO's Avatar
Default OBDI conversion makes car run irregular??????
Here is the problem. I have a 97 Accord LX with just minor bolt-on's. I-E.....Well I decided to switch to an OBDI setup. Well I bought the jumper and got a ECU from my friend and plugged it all in and the car barely ran. (By the way the ECU was out of an 94 Accord LX.) It wouldn't idol on its own and when I could get it to bring the RPM's up it was running irregular, poppin in the exhaust and what not. So I thought it could be that the ECU was making the car run rich plus the fact that the Air/fuel gauge was pegged out rich.(I know those are not accurate but it was another sign) So anyway I bought and V-afc also to try and correct the problem. (Got the v-afc intsead of afc because I am getting a H22 swap in less than a year.) Well I tried to mess with the fuel curve and idol and nothing got better so I went back to the stock ECU. Anybody know what is going on. Any help would be greatly appreciated.
Old Feb 13, 2003 | 02:43 AM
niedejb's Avatar
Default Re: OBDI conversion makes car run irregular?????? (EuRoBrO)
Will the 94 lx ecu work with the H22?
Man. I cant help you but I just added to the reasons I'm going with AEM EMS.
Old Feb 13, 2003 | 11:26 AM
johnsaccord's Avatar
Default Re: OBDI conversion makes car run irregular?????? (niedejb)
you need a p13 ecu for the h22.
Old Feb 13, 2003 | 04:30 PM
EuRoBrO's Avatar
Default Re: OBDI conversion makes car run irregular?????? (johnsaccord)
No, I do not have a H22 right now. I have a F22B non-vtec. Which I got the OBD2<1 jumper harness for and a 94 LX ECU. For some reason this ECU does not idol properly and just does not run very well at all. What ECU do you guys think will work with my 97 Accord LX. Also by the way I have the AFC now so I can adjust the fuel.
Old Feb 13, 2003 | 04:35 PM
EuRoBrO's Avatar
Also to add another note. I tried my friends ECU today which was out of a 94 integra ls and it worked fine. The idol was perfect. The only thing is that it needed to be richened up a bit but thats what the AFC is for anyways. Keep in mind this is a F22 non-vtec not a h-22. Also will a Civic DX ECU work in my car if I tune the fuel curve.
Old Feb 13, 2003 | 06:30 PM
optimis's Avatar
try a junkyard to find the ecu you want and plug it in. Might be worth a shot to see if your friends ECU is bad.
sorry
Old Feb 13, 2003 | 07:05 PM
Accord94DX's Avatar
Default Re: OBDI conversion makes car run irregular?????? (optimis)
my brother has a 96 civic that he converted to OBD1 and sometimes it idles really wierd for 30 seconds or so, then everything is fine.
funky random problems are always tough.
Old Feb 13, 2003 | 08:14 PM
EuRoBrO's Avatar
Default Re: OBDI conversion makes car run irregular?????? (Accord94DX)
This is all the time. The car doesn't stay on without me holding the gas a little bit. An experienced tech told me that the ECU will not work for my motor. He said something is diff in this ECU maybe like the timing is diff. for my motor or something else. He told me to get another ECU like off a single cam Civic and tune it with my AFC.
Old Feb 13, 2003 | 10:12 PM
Accord94DX's Avatar
I checked your post again, if I recall correctly the OBD2 F22b2 has different crank angle sensors than the OBD1 f22b2 and this might be causing some bad juju with your ecu, telling it to pull/add timing when it is not necessary.
Old Feb 14, 2003 | 07:09 AM
EuRoBrO's Avatar
Thats the type of answer I was looking for. Thank you Accord94DX. Also, what other ECU do you think that I can use?
95EG2
Dec 16, 2009 07:11 PM
919DumpedCD5
Oct 8, 2008 10:06 PM
MASTERTECH
May 13, 2005 10:10 PM
azn_nite_ryder
May 28, 2003 07:07 AM
EuRoBrO
Feb 13, 2003 04:33 PM
