g2 with exhaust on passenger side
i took my black widow rear bumper to a shop to have the exhaust hole filled in on passenger side, but the guy messed up and filled in drivers side
so my question is, would i be able to run a muffler off the passenger side with a universal muffler on stock piping until i can afford full exhaust?or will i need to get pipe bent?
.so my question is, would i be able to run a muffler off the passenger side with a universal muffler on stock piping until i can afford full exhaust?or will i need to get pipe bent?
alright...thanks guys. i have questions on if it will fit b/c or sway bar and everything but uberteg, i was wonderin what dimensions your muffler was and if you knew about how much room i have?if i order a muffler...i know someone who could bend a pipe so i could then make it fit?
ive got 2.25 custom hooked to a tsudo cf canister muffler coming out of my passenger side. cant help you on how much room you will have, but you should be able to find muffler dimensions when you purchace it
would a 5 by 8 oval magnaflow thats around 26 inches long fit?anyone that has this set up will you please let me know how long yours is?thanks
just go down and measure.
the hard part is, if youre too high and too the left, you hit the gas tank. if too high and too the right, you hit the spindle i think. if too low, you hit the sway. so in the end when you finally weld everything make sure its exactly right. i wouldnt trust a ghetto muffler shop to do this unless theyre nice and know how crucial placement is. good luck
26" is wwwaaaayyyy too big. Mine was 22", nd I had to cut off the tip, and weld a short tip on cuz the old tip stuck out abotu an inch too far. Everyone called my car, "The boner car". Very annoying
ZipTieGUy
May 1, 2006 08:52 PM
