Hydrolock...? -=[
Old Feb 12, 2003 | 04:41 PM
Richard.'s Avatar
Default Hydrolock...? -=[
Well it started raining yesterday here in LA.. and today it started pouring. I was on my way to school this morning, when i started to hear this really loud bogging noise from under my car.. not sure where exacly...front or under the hood.. but it sounded something like popping or boiling water so i put it into neutral and just let it roll on its own.. till i started going too slow i put it in 4th and next thing you know the car just turned off on me, so i got scared and turned the key to turn it back on..on like my second try it turned back on. I wasnt that far from school, so i took it all the way. On the way back from school i took mostly the side streets... well thats the story.. now i'm at home and i got a question.. do i need to do that trick of pulling out the spark plugs and cranking the motor manually?? or do i just let it sit their and will the water dry out if theirs any in it?? is it anything i should worry about?? TIA
Old Feb 12, 2003 | 04:46 PM
Chris y0!'s Avatar
Default Re: Hydrolock...? -=[ (Spoon)
yeah its been raining ******* hardcore...
about your car... if it runs, it runs. no need to pull the plugs and crank it. if its running there is no water in your system. just revv it up for a while. what kind of intake do you have?
Old Feb 12, 2003 | 04:55 PM
Richard.'s Avatar
Default Re: Hydrolock...? -=[ (Spoon Hybrid)
o yea sorry.. i have an AEM CAI.. so i guess just leave it like this over night and it will be ok tomorrow??
Old Feb 12, 2003 | 04:57 PM
Chris y0!'s Avatar
i wouldn't just leave it. let it run for like 15 minutes
Old Feb 12, 2003 | 05:15 PM
Richard.'s Avatar
k.. thnx.. i hope nothing happens.. i can't afford for my motor to break on me right now.
Old Feb 12, 2003 | 06:50 PM
keenspeed's Avatar
i would pull the plugs out and crank it over and maybe change the oil u may have bent a valve.
Old Feb 12, 2003 | 07:28 PM
Richard.'s Avatar
Default Re: Hydrolock...? -=[ (keenspeed)
yea... think the valve is bent?? well i turned it on and left it on for 15 mins it sounds ok.. would it still turn on if i bent the valve?? the oil change im just going to do till the sun comes out.
Old Feb 12, 2003 | 07:34 PM
JDMvtecDRAGSTA's Avatar
yah its been raining super hard here in LA, freakin i made my iceman a short ram as soon as i saw DAMN RAIN!!!!!!!!!!!!!!!!!!!! lol
hope ur motor runs
Old Feb 12, 2003 | 08:10 PM
miahmouse's Avatar
you would know it if you hydrolocked. either 1. car would not run at all or 2. Loud clanking coming from under the hood (like someone beating on the block with a 5lb sledge). Like was said before, if it's running ... let it run
Old Feb 12, 2003 | 08:15 PM
Neddy1081's Avatar
Default Re: Hydrolock...? -=[ (miahmouse)
it is fine man I have had that happen a few times if it starts and runs than it is ok, just now u know when ur intake is suckin up all that water so u know better now
Old Feb 12, 2003 | 08:28 PM
gumbii's Avatar
Default Re: Hydrolock...? -=[ (Neddy1081)
how much water has to fly thru the intake..... some homeboy told me that he drives it like that all the time.... and i have been driving my car all around town with the filter on.... i thought that you get hydrolock when alot of water goes into your system.... becouse the aem booth at sema had a intake sucking water from a tank.. and the water valve thing opened when the water got too heavy..... if it only takes a couple of drops of water to bust your block.... then the bypass valve doesnt work.....
Old Feb 12, 2003 | 08:29 PM
kwil666's Avatar
happend to me too so far so good. i would change the oil anyhow and see if there is any water in there. hope it all works out for you.
keith
Old Feb 12, 2003 | 08:57 PM
NiiS's Avatar
To expand upon this:
If you're unlucky enough to hear a knocking sound, you're in a lil too deep...LoL
It does'nt take much time to suck in enough H2o to break a rod, or send one through the block. Your intake will devour water in no time flat, so if you had damage, you would have already known. You probably just got your distribtor wet...You're pretty fortunate.
Old Feb 12, 2003 | 09:45 PM
BeerBaron105's Avatar
Default Re: Hydrolock...? -=[ (sinister)
u said u started to drive really slow then u put it in 4th and ur car shut off, maybe it bogged down below idle and stalled who knows
i doubt its damaged since it runs without any unusual sounds
Old Feb 12, 2003 | 10:12 PM
WongFeihung's Avatar
Default Re: Hydrolock...? -=[ (BeerBaron105)
As soon as it started getting all wet around here, I installed the short ram over the cai. Yea im paranoid, but better safe then sorry right
Old Feb 12, 2003 | 11:06 PM
Richard.'s Avatar
yea, i was pretty much scared to put it in 3rd since the more you rev, the more the intake sucks in... so i was trying to keep it low...but yah.. now that you guys tell me that if it turns on its ok.. makes me feel better.. i let it idle for 10-15 mins and everything seems fine so far.. tomorrow i'll be taking my GFs del sol to school, i'm pretty much scared that something might happen to my baby! -=x
Old Feb 12, 2003 | 11:16 PM
SiBirdie's Avatar
that's what i did today.. I got so scared that I cut my AEM in half so i made it a short ram until the rains goes away i'll turn it back into cold air.
Why is it raining so hard anyways? its goign toward summer... this is weird
Old Feb 13, 2003 | 01:15 AM
NiiS's Avatar
Default Re: Hydrolock...? -=[ (SiBirdie)
LoL. We're in the dead of winter in case you did'nt notice not to mention we (usually) get most of our rainfall in late January-late March, so be prepared....It aint over yet. Besides, we need the snowfall, too, I'm so depressed ( B/c I have only been up once this year )
[Modified by sinister, 3:16 AM 2/13/2003]
Old Feb 13, 2003 | 01:31 AM
eg_nezay's Avatar
y0 Sin we gotta hit the snow wit the boards
Old Feb 13, 2003 | 02:39 AM
EK MONEY's Avatar
Default Re: Hydrolock...? -=[ (eg_nezay)
get that **** out of your cylinders! dont let the water sit.. That will **** up your cylinders bad! Are you sure that is what is was? it could be a connection of some sort... Oh, and rain??? WTF??
Old Feb 13, 2003 | 09:54 AM
ejprimo's Avatar
its el nino season.
Old Feb 13, 2003 | 09:59 AM
nerces's Avatar
Default Re: Hydrolock...? -=[ (ejprimo)
its el nino season.
EL NINO is fun (WITH A REAR WHEEL DRIVE) hehe i drift in my BMW when it rains LOL its so damn fun!
Old Feb 13, 2003 | 10:16 AM
EVIL Hx Coupe's Avatar
Default Re: Hydrolock...? -=[ (nerces)
Like 2 weeks ago my intake sucked in water when I was cleaning my engine.... My car was making weird noises. I let it idle for like 20 mins and it's been fine since then.
f23accord
Dec 1, 2004 12:03 PM
ShakesTheKlown
19
Dec 5, 2003 04:34 AM
MugenHonda
May 3, 2003 10:25 AM
Conechaser
May 4, 2002 08:27 PM
