people with '00 hb sway ?
iam looking to put a front stock si sway bar on my hatch and want to know if integra lower control arms are interchangable with the civics b/c i believe the hatch does not have the mounts for the bar.
I added an EX sway bar up front on my EK. The stock CX/DX lower control arms do not have the predrilled holes for the sway bar. I am not sure if the Integra LCA's will fit an EK? But the stock ones are not drilled.
If you want the 26mm SI sway bar you need the sway bar, SI lower control arms, and SI damper mounting forks. If you want to do the 22mm EX bar you only need the bar and EX lower control arms.
hondacurious
Jul 25, 2010 08:49 PM
