HELP ! Cylinder Position Sensor
That I'm not sure of for the OBD1 Diz. But you can take any sensor from a 88-91 I know. You can use either of the 2 in a DX or 3 from a SI/EX or even a 90-91 teg. As long as the resistance is within specs. Done it at least 3 times already. They all are shaped the same way and all work the same way the only thing thats difference is on the shaft theeth count 1,4, forgot the last #
[Modified by zCivic, 11:29 AM 2/12/2003]
TravisCadello
14
Feb 6, 2013 07:40 AM
