MTK ! I need ur help with hid's....everyone else welcome for advice
i just purchased a pair of audi projectors.
I plan on putting them in my integra headlights in place of the stock ones so i can run OEM hid.
Anyhow, MTK, what do you know about taking the old projector out and making the new ones fit in their place? any modifications to make the projector mount? how does it mount into place?
thanks in advance
thanks in advance
I am also intrested on how this is done!
MTK normally hangs out in the apperance forum though I believe
Yep, if you really want to find him quick, look for carbon fiber hood threads
LOL
You should really read up on this website: http://faq.auto.light.tripod.com/
Lots of information on how to do the swap.
You can use mounting brackets, screws, wingnuts, epoxy, jb weld, it really depends on how you want to go about it!
What is wrong with everyone? Nobody takes pictures!
-skafia, who will be tackling this problem this weekend, btw, what Projectors did you get?
i got the audi a4/s4 projectors
i'm wondering about the placement of the bulb holders relative to the outside housing of the integra headlight housing. the projector bulb holders have to extend past the back of the headlight so you can put the socket over it...
actually.. i know nothing about the OEM integra projectors.. BUT there is one guy who has done this on a 2000 type R.. maybe he can assist you..
http://www.illusion-lighting.com/gal...Integra_p.html
if u search around somewhere on that site, you can probably find contact info.. sorry i couldnt be more help, but ive never taken apart an integra headlamp..
Well unless this casing around the projector can be removed, it looks like it might be a difficult swap:
interesting
nice pic
do you have any others of just the projector part?
any way to take that off?
nice pic
Guest
Posts: n/a
All you have to do is heat up the housing in an oven!
Whatever happens, we better get a step by step tutorial at the end of this...
Some of us are too lazy to be pioneers, but still want results
that looks like an A6 projector.. the A4 ones are all closed up.. you cant see inside them.
MTK - yeah, the AUDI Projectors are amazing. The blue cut off line is awesome and the flicker is cool too!
Notice how sharp the cutt of line is (even with the fucked up reflector)
[Modified by skafia, 9:44 PM 2/16/2003]
did u finish the conversion?
do you have instructions on how to open the injector projector section?
We finished one headlight, we're doing the other tonight. Check my other thread for pictures of the brackets that we made.
To open the headlight preheat your oven to 400 degrees. Place headlight on cookie sheet (where it doesn't touch the oven directly). Turn the oven off. Let the headlight sit in the oven for 10 minutes. Take it out and pry it open with a butterknife. It is very hot and its hard to take it apart, you need a friend to pull it apart. Also, don't forget to remove all of the rubber hoses/plastic pieces of the back of the headlight or it might melt, and don't forget to take out the bulbs as well!
bboyprelude
Mar 5, 2005 08:48 AM
tfalconier
Feb 12, 2004 01:52 PM
