Civic SI DC Header is the same of GsR?
Old Feb 11, 2003 | 09:00 PM
Joel GsR's Avatar
Default Civic SI DC Header is the same of GsR?
Old Feb 11, 2003 | 09:13 PM
Joel GsR's Avatar
Default Re: Civic SI DC Header is the same of GsR? (Joel GsR)
Si DC header fit in 94` GSR?
Old Feb 11, 2003 | 10:17 PM
threatcon13's Avatar
New User
no
Old Feb 11, 2003 | 10:24 PM
97hb's Avatar
You can make it work . Should bolt to the head but not the cat.
Old Feb 11, 2003 | 10:27 PM
neo1z's Avatar
Default Re: Civic SI DC Header is the same of GsR? (97hb)
indeed, the length will be off.
Old Feb 11, 2003 | 11:36 PM
integobsession's Avatar
Default Re: Civic SI DC Header is the same of GsR? (neo1z)
Yup.
Old Feb 12, 2003 | 12:27 AM
tC_Dragon's Avatar
Default Re: Civic SI DC Header is the same of GsR? (integobsession)
it will bolt to the head, all b-series have the same setup on the head for the manifold so pretty much any of them can be swapped to bolt up, but whether it will work with the rest of your cat and exhaust setup is a different story.
Old Feb 12, 2003 | 06:34 AM
MetalGunSI's Avatar
Default Re: Civic SI DC Header is the same of GsR? (pdcdragon)
secondary will not fill under the oil pan, b16 has a shorter block than a b18.
syknxv3
Oct 20, 2009 10:03 PM
tightflks
Nov 18, 2007 06:42 PM
o0h5hitS0n
Dec 3, 2005 03:46 PM
neEven
Jun 23, 2004 09:20 AM
AllmotorJunkie
Mar 31, 2003 05:07 PM
