help me...i gotta do this tonight
Old Feb 11, 2003 | 07:46 PM
RS_91's Avatar
Default help me...i gotta do this tonight
i was drivin my car and i noticed it sounds totally diferent for some reason today. i ignored it for a while hoping it would go away but no luck. I started lookin around and under the car a noticed a little leak at where the header connects to the cat. theres just 2 ****** screws on a spring holdin the damn thing in place and its leakin a little at the cat.
is this a big problem that should be fixed right away? does it matter at all, i mean should i fix it right away. what do u guys think....i havnt noticed a change in the car as far the driving goes. let me know, thanks for the help.
Old Feb 11, 2003 | 07:49 PM
civicmandx94's Avatar
Default Re: help me...i gotta do this tonight (Civic_EX)
If it is only leaking a little bit then it shouldn't be a huge problem. It is when it starts leaking alot that you have to worry.
Old Feb 11, 2003 | 07:50 PM
TRENDSETTLER's Avatar
tighten the bolts down...haha...if you say that it wasnt leakin before then it could just be loose? you will lose a little backpressure if its a big leak or anythin
Old Feb 11, 2003 | 07:54 PM
RS_91's Avatar
i have tightened the bolts all the way but the header doesnt exactly line up perfect so thats why its leakin. i just dont feel like taking every thing apart right now to line it up. would i loose hp from this? i would think not, but let me know.
Old Feb 11, 2003 | 07:57 PM
if its a tiny leak you wont be able to notice besides the noise...if you are loosin a lot of backpressure then you will lose some low end power...im guessin that your leak is tiny and you wont be able to tell at all
Old Feb 11, 2003 | 08:01 PM
RS_91's Avatar
Default Re: help me...i gotta do this tonight (TRENDSETTLER)
alright, thanks for the help. i'll probly take it apart tomarrow and fix it.
killakoupe
Oct 27, 2006 07:17 PM
TeGGY_LS
Jun 8, 2004 11:24 AM
urquidezj
Apr 5, 2004 02:12 PM
ggangtong81
Oct 1, 2003 06:40 AM
AWDSOME
Aug 28, 2001 03:05 PM
