idle control valve connection to p28
Old Feb 11, 2003 | 07:13 PM
TypeR0wnz
Guest
Posts: n/a
Default idle control valve connection to p28
The wires from it off a 95 Gsr's manifold is not connected and i need to connect the 2 wires to a p28 ecu. where does it connect to on the ecu. Sorry but i need to know this in a hurry and type r forum answers are fast and detailed. its important i need this hooked up to take the check engine off by tomorrow
Old Feb 11, 2003 | 07:25 PM
baonest1's Avatar
Default Re: idle control valve connection to p28 (TypeR0wnz)
2 wires or one.. are you talking about the 2 wires strait from the connector of the IAC.. one wire is ground.. one wire is power.
Old Feb 11, 2003 | 07:34 PM
TypeR0wnz
Guest
Posts: n/a
Default Re: idle control valve connection to p28 (baonest)
that power wire what does it hook up to exactly battery? ecu? and if it is the ecu which pinout
Old Feb 11, 2003 | 11:10 PM
integobsession's Avatar
try the tech forum, i kno they dont respond as quickly i think as the integ forum, but you'll get input from some very knowledgable peopel there.. good luck and free bump cuz car trouble just sucks
808DA
Nov 23, 2009 05:51 PM
v8 integra
Sep 20, 2007 02:50 PM
