Whoever has installed ES bushings, or not, I have a question.
Old Feb 11, 2003 | 06:41 PM
my_slow_civic's Avatar
Default Whoever has installed ES bushings, or not, I have a question.
Okay, for some reason I decided to start my bushing set today. I have come across a set of bushings, for the upper and lower ball joints, and the steering rod.
Well, here is this:
http://www.automotiveforums.com/kris...ball_joint.jpg
And here is the bushing next to the joint.
http://www.automotiveforums.com/kris..._joint_new.jpg
http://www.automotiveforums.com/kris...joint_new1.jpg
Is that right? How do I put it on? Do I just cut the old rubber bushing off, and slide the new one on? If so, do I need to lube it slightly with axle grease?
Thanks
edit: click the link for pics
[Modified by sirk, 8:43 PM 2/11/2003]
Old Feb 11, 2003 | 06:45 PM
Default Re: Whoever has installed ES bushings, or not, I have a question. (sirk)
Well ****, why the fu.. I cant link to my space.
Well, if anyone can help, here is a thread about it also.
http://www.automotiveforums.com/vbulletin/t86545.html
[Modified by sirk, 8:46 PM 2/11/2003]
Old Feb 11, 2003 | 07:19 PM
Toptul_Honda's Avatar
New User
no need to use those
im putting my ES bushing master kit on too. did u do the rear LCAs yet? im finding them very hard to hammer out compared to the Front LCAs i have an 88 btw
[Modified by G2-Rex, 8:21 PM 2/11/2003]
Old Feb 11, 2003 | 07:22 PM
MADEINIRAQ's Avatar
Default Re: Whoever has installed ES bushings, or not, I have a question. (G2-Rex)
those are dust boots... to correctly put them on.. you separate the balljoint and pop the retaining clip off the original dust boot.. and then slide on the new one.
I would not even bother putting them on
Old Feb 11, 2003 | 07:45 PM
New User
Default Re: Whoever has installed ES bushings, or not, I have a question. (madeiniraq)
yeah theres an opening so dust can get in and destroy your ball joints
Old Feb 12, 2003 | 09:37 AM
Thanks.
I am staring the lca's today.
Old Feb 12, 2003 | 09:39 AM
New User
tell me how u get those rear LCA metal sleeves out
Old Feb 12, 2003 | 07:32 PM
Torino91LS's Avatar
You use a acetylne torch, set the rubber on fire let it burn. Once that is done let it cool, then use an air chisel to knock out the Bushing case.
Old Feb 13, 2003 | 08:48 AM
upstatecrx's Avatar
Default Re: Whoever has installed ES bushings, or not, I have a question. (kincaidcrxsi)
i used to sawall on all the metal sleeves to slit them in 2 spots. then with the air chisel i popped them out. you can also use a hand chisel to get in between the sleeve and control arm and then hammer it out. once it starts to move it will pop right out. the key is to cut the sleeves first.
Old Feb 13, 2003 | 09:38 AM
This is the method I am using.
http://home.socal.rr.com/civic4dr4g/...tall/index.htm
Old Feb 14, 2003 | 01:08 AM
New User
i gave up and i gave them to my local mechanic t press em out.. im weak!?
Old Feb 14, 2003 | 12:09 PM
New User
i decided not to use the Rear lca bushings. so i am going to sell my 88 rear lcas and the bushings to go with it
Old Feb 14, 2003 | 02:25 PM
JoshDM's Avatar
ES bushings=pain in da ***!
Old Feb 15, 2003 | 08:40 AM
Torino91LS's Avatar
Default Re: Whoever has installed ES bushings, or not, I have a question. (JoshDM)
How the hell do u install the Rack and Pinion Bushings? Do you have to drop the rack or what??
Old Feb 15, 2003 | 11:02 AM
As far as I know. So umm.... i dont think I will be doing mine this round.
Old Feb 15, 2003 | 11:45 PM
New User
yeah you do, i tried this today and it wouldnt drop out easily, so i just replaced the bigger bushing... ill do the 4 other ones when i figure out a way
Da_1991
Suspension & Brakes
Dec 7, 2012 06:34 PM
deschlong
Apr 25, 2011 10:45 AM
shiftyB18DC2
May 31, 2008 11:09 PM
O RLY
Apr 2, 2007 05:03 AM
tylerdurden
Feb 7, 2003 01:53 PM
