FS:J&S safe guard
Old Feb 11, 2003 | 06:24 PM
Black DC2's Avatar
Default FS:J&S safe guard
$400 IM for pics
Using a single knock sensor, the system detects the onset of detonation and retards the timing on a per cylinder basis. A mode switch lets you select a maximum of either ten degrees or twenty degrees of knock retard. In the ten degree range, the unit retards one, two, or three degrees per ping. Double that for the twenty degree range. The system is always trying to re-advance to stock timing. In the ten degree mode, it re-advances at the rate of one degree every twenty revolutions.
The system does not need a cam or crankshaft reference to determine which cylinder to retard. The unit is programmed to "know" that the knocking cylinder is the one that just fired, and that it won't fire again for two more revolutions. When the knocking cylinder comes around to fire again, software dials in the retard amount for that cylinder. It does this as each cylinder goes by, building up a different retard amount for each cylinder.
[Modified by Black DC2, 10:30 PM 2/11/2003]
tuna-can
Oct 14, 2009 05:53 AM
DC4jdmIntegra
May 3, 2009 10:28 AM
imzjustplayin
Engine Management and Tuning
Feb 18, 2009 01:18 PM
SpOoLiNg CiViC
Dec 23, 2006 11:39 AM
fastcivicboy
Apr 27, 2005 11:21 AM
