Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
22mm rear sway bar and 600lbs springs
Old Feb 11, 2003 | 05:17 PM
DOHCTOR's Avatar
Default 22mm rear sway bar and 600lbs springs
just wondering how effective a 22mm rear sway bar is in an eg hb with 600lbs rear springs, 400lbs front for autocross, will the high spring rate cancel the effectiveness of the sway bar. has anyone experienced this?
Old Feb 11, 2003 | 06:14 PM
solo-x's Avatar
Default Re: 22mm rear sway bar and 600lbs springs (DOHCTOR)
no. the springs will not cancel the effect of the swaybar.
are you using a front swaybar?
nate
Old Feb 11, 2003 | 06:15 PM
Ausmith's Avatar
That is a pretty good combo for autocross.
IF you ever take it to the track make sure you have your brake bias correct and do ALL of your braking in a straight line
Old Feb 11, 2003 | 06:19 PM
solo-x's Avatar
Default Re: 22mm rear sway bar and 600lbs springs (Ausmith)
how do you know this? just curious, cause i have no idea.
nate
Old Feb 11, 2003 | 06:24 PM
Ausmith's Avatar
Default Re: 22mm rear sway bar and 600lbs springs (solo-x)
I run a very similar set-up on a 95 hatch
Old Feb 12, 2003 | 12:33 PM
solo-x's Avatar
what class are you going to be racing in?
nate
Old Feb 12, 2003 | 02:55 PM
Ausmith's Avatar
D mod.
Old Feb 12, 2003 | 03:00 PM
solo-x's Avatar
not you. the dohctor.
VarTheVar
35
Jun 23, 2018 05:23 PM
VarTheVar
Suspension & Brakes
15
Apr 27, 2018 02:36 PM
Spawne32
Suspension & Brakes
18
Apr 21, 2010 06:33 AM
Blown90hatcH
11
Oct 8, 2002 12:59 PM
Spade
36
Mar 4, 2002 11:39 AM
