Jesss, just do it daymit. A2 &A3 head pics.....
Old Feb 11, 2003 | 02:42 PM
B18CXr's Avatar
Default Jesss, just do it daymit. A2 &A3 head pics.....
Since everyone is bitching about the heads and what they look like.......
Old Feb 11, 2003 | 02:46 PM
oldB18EF's Avatar
Default Re: Jesss, just do it daymit. A2 &A3 head pics..... (B18CXr)
youll need the intake manifold too if you swap from the A3 to the A2
Old Feb 11, 2003 | 02:51 PM
B18CXr's Avatar
what makes you say that??
as long as there is room for the mani and you a way to pull the runner solenoid high/low, you should be golden.
Old Feb 11, 2003 | 02:58 PM
MK Ultra's Avatar
It does look like the 3-rocker setup would fit in there. Cam caps look the same too...
oldB18EF's Avatar
the A3 manifold would prob hurt performance their both meant for different things
Im not saying youre wrong, im just sayin if you swap over heads, it would probably be a good idea to switch over to the single runner A2 manifold too
Old Feb 11, 2003 | 03:01 PM
MK Ultra's Avatar
Default Re: Jesss, just do it daymit. A2 &A3 head pics..... (WR93EG)
If you're going to swap manifolds, why not get the K20A version with larger single runners than the A2 version?
Old Feb 12, 2003 | 07:06 AM
ep3minivan's Avatar
Default Re: Jesss, just do it daymit. A2 &A3 head pics..... (MK Ultra)
B18CXr, how is everything working out so far?
Old Feb 12, 2003 | 09:27 AM
B18CXr's Avatar
so far, so good...will be running around the end of de month YO!!
Old Feb 12, 2003 | 09:31 AM
Johnny Tran's Avatar
Old Feb 12, 2003 | 09:41 AM
oldB18EF's Avatar
ahhh see now that I read your sig, I understand where your comin from...youve got an EP, which already has the Type S manifold.
Thought you had a base DC5.
Old Feb 12, 2003 | 09:44 AM
B18CXr's Avatar
Old Feb 12, 2003 | 12:01 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Hey what setup are you running? Are you using the K24block/A2 head? Sounds interesting?
Old Feb 12, 2003 | 06:44 PM
PhxK20a3's Avatar
AFAIK,the A3 in the Si uses the same manifold as the A2 in the type S
Old Feb 13, 2003 | 07:13 PM
Halo's Avatar
Default Re: Jesss, just do it daymit. A2 &A3 head pics..... (Charged2000Si)
A3 VS A2 which flows better?
Old Feb 14, 2003 | 09:15 AM
khoalie's Avatar
Default Re: Jesss, just do it daymit. A2 &A3 head pics..... (Halo)
vtec E!!!!
Old Feb 14, 2003 | 02:22 PM
eccentric.ek's Avatar
Default Re: Jesss, just do it daymit. A2 &A3 head pics..... (khoalie)
dam the head looks nice!! vtec e owns
TheRookie74
Oct 16, 2014 09:17 AM
Noobster425
Apr 13, 2010 06:33 PM
spoolinhatch123
Sep 25, 2007 05:16 AM
s2k3_oc08
Aug 8, 2006 09:50 PM
remo
Jul 3, 2006 06:03 PM
