Door Panel ?
Hey guys, I was wondering if any of you have taken your door panels off, only to not be able to get them to go back on correctly. The end up by the front of the car sits up higher than it did before I took them off and it also sits further out from the door. The clips that hold the door panel on are not bent/broken and it's rattling and about to drive me crazy!! Somebody please help!!!
It sounds like your door panel just isn't seated properly on those gray "plugs." Take the the panel back off pull all the little gray plugs out of the door frame, slide the plugs into their respective "seats" on the inside of the door panel and then pop that bad boy back on. You should hear everything pop back in nicely.
suhteevin
Jan 6, 2009 09:04 PM
aimbot
Jul 13, 2008 05:24 PM
