How to take off interior door panel
Old Feb 11, 2003 | 11:44 AM
[HrZn]4life's Avatar
Default How to take off interior door panel
Hey guys. My neighbor recently backed into my car and dented my driver side door. The damage is minor and I'm going to push it out myself. I was just wondering how difficult it is to remove the inner door panel so that I can get to the door panel. I haven't looked at it yet...just wanted to get some input from you guys. TIA.
Reid's Avatar
Global Moderator
Default Re: How to take off interior door panel ([HrZn]4life)
Get a Helms.
Old Feb 11, 2003 | 11:46 AM
Default Re: How to take off interior door panel (Reid)
planning to do it tonight and I don't have time to go pick one up today. Thanks anyways.
Old Feb 11, 2003 | 11:50 AM
Reid's Avatar
Global Moderator
Remove speaker grill.
Remove all screws.
Make sure window is down (duh).
Remove panel.
Old Feb 11, 2003 | 11:57 AM
sgT's Avatar
sgT
1 screw on door handle trim, remove
1 screw on door pocket/handle thing, remove
one plastic screw on upper right, remve
then pull from bottom right around to left
Old Feb 11, 2003 | 11:59 AM
cheezthis's Avatar
Default Re: How to take off interior door panel (sgT)
Don't forget to unplug the wires for the door locks and when pulling the panel off
Old Feb 11, 2003 | 12:15 PM
jeffrey's Avatar
instead of pulling.. i grabbed a fat *** butcher knife, and wrapped it all around with masking tape, and then i wedged it in between the door and the panel, and removed the 8?? clips that hold the door to the panel. starting from bottom, to right, then to left, and then pull out the top part.
Old Feb 11, 2003 | 12:25 PM
skafia's Avatar
25 Year Member
Default Re: How to take off interior door panel (jeffrey)
Don't forget that it is held on by plastic tabs on all sides and the bottom. It might seem like you're breaking something but don't worry, its just stubborn.
Also, when reinstalling the panels, make sure you have it aligned correctly with the window guards and rubber things at top.
Reid - you jackass.
[Modified by skafia, 2:17 PM 2/11/2003]
Old Feb 11, 2003 | 12:26 PM
TypeR 01 886's Avatar
The easy part is getting it off. The hard part is putting it back on. Once all scews are out and everything is ready... then push up on the panel. Do not try to pull it straight off towards you. Then do the same when putting it back on. (Slide downwards)
Old Feb 11, 2003 | 12:55 PM
HondaRcB's Avatar
Default Re: How to take off interior door panel (TypeR 01 886)
Yeah after my window was broken, I took the door panel off to the the broken pieces of glass out of the bottom of the door. Getting it off was no problem, finessing it back on took some patience.
Old Feb 11, 2003 | 01:13 PM
Default Re: How to take off interior door panel (HondaRcB)
Thanks guys.
Old Feb 11, 2003 | 01:16 PM
Reid's Avatar
Global Moderator
Once you get the leading edge of the panel in the window groove, the rest of the panel will follow.
Old Feb 11, 2003 | 01:21 PM
ragejed's Avatar
How about dont post in both integra forums..no need to.
https://honda-tech.com/zerothread?id=412691
alex1321
12
Jan 25, 2013 08:59 PM
Nuts
Honda S2000
Aug 7, 2008 06:32 PM
todd.ludwig
May 1, 2006 02:27 AM
teg95
May 22, 2002 01:16 PM
onyx00
Sep 5, 2001 12:44 PM
