Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Gsr Abs
Old Feb 11, 2003 | 09:25 AM
Madracer1's Avatar
Default Gsr Abs
How does the GSR ABS compare to the Type-R one? From what I have researched the TypeR ABS is really close to threshold braking and really worthy. How does it compare to the GSR one? Anyone out there tried to disable(not remove) ABS on the track and see if it braking distances will improve? Please share your expreinece!!
Thank you!
Rado
Old Feb 11, 2003 | 09:30 AM
SPiFF's Avatar
Default Re: Gsr Abs (Madracer1)
The ABS is the same. Though 97 and older cars had a different design. The older ABS is an NEC computer and the modulator was a closed system with it's own fluid. The 98+ model uses a Nissin computer and the modulator is much smaller pulling fluid from the main resevior.
I have no data on the performance of each unit, but the 98+ is a much better system with much faster pulses. I would guess more then 2X just from feel. The pedal feel is much better on the 98+ system as well.
EDIT: I prefer to use the ABS on track. The 98+ is very track worthy. There are several folks on here who run the older system as well. I now have an older car, so I will know in 2 weeks how it feels on track. Thus far I have only experienced the older system on the street.
[Modified by SPiFF, 1:41 PM 2/11/2003]
Old Feb 11, 2003 | 11:47 AM
maxQ's Avatar
Default Re: Gsr Abs (SPiFF)
Really?
The ABS on my 2000 GS-R sucked...
The better brakes of a Type-R make it THAT much better?
Old Feb 11, 2003 | 12:41 PM
chad's Avatar
Moderator
Default Re: Gsr Abs (maxQ)
Really?
yes the size of the brakes would make it that much better!!!
Old Feb 11, 2003 | 01:17 PM
SPiFF's Avatar
Really?
Sucked? As compaired to what? There are cars with much worse feeling ABS then the 98+ Integra.
Old Feb 11, 2003 | 01:55 PM
maxQ's Avatar
Maybe I'm spoiled... I just figured Honda would've caught up in the 5 years between models... ('93 vs. '98 ) And I hear such fantastic things about the ITR ABS, I figured it was a unique design...
*shrug*
DC2 to AP2
Oct 12, 2009 04:08 PM
get RIGHT
Suspension & Brakes
Jun 23, 2009 11:59 PM
beanbag
Feb 19, 2009 02:23 AM
acurasquirrel
12
Nov 2, 2003 06:02 PM
