looking for stock spring rates
I've talked to five spring companies today and so far three don't have the OE CRX rates available (the cars are up to 15 years old!). Still hoping the other two might have something for you. I'll post when and if I hear it.
I doubt it is that high...Integra GSR: f/r - 212 lb/in 117 lb/in
even Tenzo R lowering springs are 243/200
I'm thinking of making some device where you add weights and see how much it takes to make the spring compress an inch. I doubt I would be able to make it precise enough, though.
dc1/2, db6/8 - fr: 3.6kg/mm - rr: 2.0kg/mm
itr - fr: 4.4kg/mm - rr: 2.5 - 4.4kg/mm (progressive)
eg1/2/4/5/6/8/9 - fr: 3.2kg/mm - rr: 1.8kg/mm
ek3/4 - fr: 3.6kg/mm - rr: 2.2kg/mm
ek9 - fr: 4.3kg/mm - rr: 4.2kg/mm
ah, ****, just re-read the original post/request; un-4gen-ate.
[Modified by slofu, 8:13 AM 3/28/2003]
