apex'i autotimer a/f help
Old Feb 10, 2003 | 11:59 PM
nd8ch's Avatar
Default apex'i autotimer a/f help
i've been using my autotimer for about a month now, and just found out that the closer the a/f ratio is to 20, the leaner. but for my case the light shows green. for the voltage mode, the closer the number is to .1, the greener the led shows. I think the led's are reversed, or are they? Is this normal for this product? or is there a setting or mode, or option i have to set to correct this?
[Modified by nd8ch, 2:44 AM 2/12/2003]
Old Feb 11, 2003 | 08:09 AM
nd8ch's Avatar
Default Re: apex'i autotimer a/f help (nd8ch)
ttt
Old Feb 11, 2003 | 01:44 PM
nd8ch's Avatar
bump
Old Feb 11, 2003 | 05:38 PM
nd8ch's Avatar
to the top
Old Feb 11, 2003 | 05:41 PM
ion_four's Avatar
I think you might want to rephrase your question, it is a little confusing...are you saying that you are showing an o2 voltage of .1v?
Old Feb 11, 2003 | 05:46 PM
nd8ch's Avatar
Default Re: apex'i autotimer a/f help (ion_four)
right now at WOT i get about 14.1 a/f ratio, and ~.7 volts. When i idle, i get .01 and an a/f ratio of 20, in both modes it blinks green when i idle...but when i driving its orangy/red. Is this normal?
Old Feb 11, 2003 | 09:43 PM
p0gi's Avatar
The meter is not accurate. I have the same turbo timer, and I have a wideband o2, and have watched them both side by side. The apexi is all over the place. It doesnt read accurately. I wouldnt even suggest tuning with it because you will never know where your really at. 4 wire 02 sensors are not accurate.
Old Feb 11, 2003 | 09:47 PM
diamondstar36's Avatar
Tuning off O2 voltage on a turbo car is a bad idea. O2s are not very accuate unless you've got a wideband. Even then it's still better to tune off EGTs and knock.
[Modified by diamondstar36, 6:49 AM 2/12/2003]
Old Feb 11, 2003 | 10:00 PM
Sleepin''s Avatar
Default Re: apex'i autotimer a/f help (diamondstar36)
We all know tuning off of a regular O2 sensor is innacurate thats for sure.
But, to answer your question the LED's on the TT can be set. Check on the setting of the a/f (pull to left?) and you can adjust the LED I believe. Dont take my word as law, I have been using mine for 3 months and have yet to decipher the Japanese instructions.
I hope that helped.
Old Feb 11, 2003 | 10:20 PM
nd8ch's Avatar
Default Re: apex'i autotimer a/f help (Sleepin')
the english instructions are on apex's website. Mine came with english and japanese instructions. anyway, i didnt see a setting for led's. Does yours do what mine is doing, or are your led's opposite of mine? mine: red when rich, and green when lean
Old Feb 11, 2003 | 10:26 PM
Sleepin''s Avatar
Mine can go from red if lean to orange, yellow then green around 10.8 then starts turning again around 12.5 or so back to red.
So I am thinking it gives a warning if it is either lean or rich. I seriously dont pay too much attention to the LED's. I keep it on the a/f display, although not too accurate it still gives me some kind of idea. Can you give me a link to those instructions?
[Modified by Sleepin', 2:27 AM 2/12/2003]
Old Feb 11, 2003 | 10:44 PM
nd8ch's Avatar
yup...so my led's are backwards. Oh well, everything else seems to be working fine. Its just confusing to see a number that doesnt correspond to the right color, and having your mind set to it...anyways, here is the link:
http://www.apexi-usa.com/documentation.asp
thanks for your input
Old Feb 11, 2003 | 11:07 PM
Sleepin''s Avatar
NP, I wish I coulda been more help.
ImPuLsIvE
Oct 9, 2007 09:53 AM
frog169
Dec 13, 2005 07:53 PM
LordVtec
Oct 3, 2002 07:53 PM
