Replacement Oxygen Sensors on B16-- Do you guys recommend a Bosch Universal?
Old Feb 10, 2003 | 10:43 PM
T_Rex's Avatar
Default Replacement Oxygen Sensors on B16-- Do you guys recommend a Bosch Universal?
I tried searching for info on the one-wire sensors, but couldn't find anything. Would you suggest Bosch or another brand?
When I go to the auto parts store, do I just ask for Bosch Universal one-wire ones, or do I tell them I have a JDM B16 (first-gen with 2 sensors) engine? Is there a part number? And how much do they cost?
Thanks!
[Modified by T~Rex, 12:11 AM 2/11/2003]
Old Feb 10, 2003 | 10:58 PM
d-wreck's Avatar
Default Re: Replacement Oxygen Sensors on B16-- Do you guys recommend a Bosch Universal? (T~Rex)
id go to one of the discount honda oem parts... most of the none oem ones are junk... but who knows maybe bosch even makes them for honda... id ask a honda store and see who they are manufactured by and cut out the honda franchise to save 50 or so bucks
derek
Old Feb 10, 2003 | 11:17 PM
polycrx's Avatar
Default Re: Replacement Oxygen Sensors on B16-- Do you guys recommend a Bosch Universal? (d-wreck)
i went to western auto aout close to my place. Its a mom and pops place but I just got a universal o2 sensor and it works fine. my car idled better and milage went up. Its been about 7 months and my milege hasnt gone down yet. All the guys asked was if it was one or two wire. I guess the mostly have the same tolerances
Old Feb 11, 2003 | 12:41 AM
C-RICKS's Avatar
Default Re: Replacement Oxygen Sensors on B16-- Do you guys recommend a Bosch Universal? (polycrx)
What do oxygen sensors go for $$$$?????
My gas milage has come down quite a bit.
Thanx fellas!!
Old Feb 11, 2003 | 04:11 AM
crx91's Avatar
Default Re: Replacement Oxygen Sensors on B16-- Do you guys recommend a Bosch Universal? (C-RICKS)
I'd go with NGK, the stock honda o2 sensors are made by NGK. Just order 'universal one wire' for honda, that's what i'm using on my b16a1 and they work perfect.
The price difference between honda and an auto performance shop is amazing, you wouldn't believe it! Honda wanted $250 AUD each . NGK from auto shop $45 AUD each . The only difference with the ones from honda are that they have the plug attached to go straight into the harness, they charge an extra $205 AUD just for the stock plug
Here's the part number i used: OZA401-E71
Hope this helps you out.
Regards
Shaun.
[Modified by crx91, 1:20 PM 2/11/2003]
[Modified by crx91, 1:30 PM 2/11/2003]
Old Feb 11, 2003 | 05:53 AM
Doodoo's Avatar
Get one from oxygensensors.com. They are affordable too and look stock. The ones from here have lasted the most amount of time for me. The bosch last for me about 2 months max. Thats just me though.
Old Feb 11, 2003 | 09:17 AM
T_Rex's Avatar
Default Re: Replacement Oxygen Sensors on B16-- Do you guys recommend a Bosch Universal? (crx91)
Regards
Shaun.
Are those Australian dollars? Also, that part # is an NGK number, right? Thanks a lot for the info!
Old Feb 11, 2003 | 10:44 AM
T_Rex's Avatar
I've tried every local parts store and nobody carries the NTK (NGK brand) sensors...they only carry Bosch. I can only find them online at http://www.sparkplugs.com
Has anyone found these locally or should I just go with the Bosch?
[Modified by T~Rex, 11:51 AM 2/11/2003]
Old Feb 11, 2003 | 10:51 AM
Tyson's Avatar
just get he bosch, they are a quality sensor. the universal or the OEM is fine. if you get the universal you need to reuse the old connector but that will allow you to custom length it if you have an aftermarket header.
Old Feb 11, 2003 | 11:07 AM
rioninja's Avatar
I've always had good luck with bosch. They heat up pretty quick, and have great response time.
I have run volvo and saab o2 sensors in the past as well, which are also
made by bosch if i remember correctly.
Old Feb 11, 2003 | 11:09 AM
T_Rex's Avatar
Default Re: Replacement Oxygen Sensors on B16-- Do you guys recommend a Bosch Universal? (Tyson)
Yeah, I was going to go with the Bosch, but I've read a lot of mixed reviews on them here on H-T. Many people say they've never had any problems, but many others (like in this thread) have said that they're crap and they have to replace them every month.
Old Feb 11, 2003 | 11:11 AM
Mugen Dom's Avatar
Default Re: Replacement Oxygen Sensors on B16-- Do you guys recommend a Bosch Universal? (Rioninja)
german crap they work ok went through 3 of em in a week untill i got my **** runnig right now its been in for about a year
Old Feb 11, 2003 | 11:25 AM
stockcrx's Avatar
Default Re: Replacement Oxygen Sensors on B16-- Do you guys recommend a Bosch Universal? (JdMB16Ahatch)
yeah i think i am goign to replace my o2 sensors. if you go to advanced auto or something there like 19 bucks a pop. now times it by 2.
Old Feb 11, 2003 | 11:29 AM
T_Rex's Avatar
Default Re: Replacement Oxygen Sensors on B16-- Do you guys recommend a Bosch Universal? (stockcrx)
What brand/kind do you suggest then? NTK??
Also, how would I check to see if my stock ones even need to be replaced?
[Modified by T~Rex, 2:03 PM 2/11/2003]
Old Feb 11, 2003 | 01:07 PM
T_Rex's Avatar
I guess I'll go with the Bosch (part# 11027). I found it for $24 each locally. Is that price about right?
Old Feb 11, 2003 | 05:17 PM
T_Rex's Avatar
Is Advanced Auto local in your area or is it an online store?
Old Feb 11, 2003 | 10:16 PM
dub204's Avatar
i read in another post that each O2 sensor has a different frequency or something, which is why when u switch them the car runs differently. I assumed this was true and so wouldnt you need to get 2 different O2s for different frequency??
Old Feb 12, 2003 | 05:22 AM
crx91's Avatar
Default Re: Replacement Oxygen Sensors on B16-- Do you guys recommend a Bosch Universal? (dub204)
Each sensor has a different plug on the end that corrosponds to the same color plug on the harness, a green plug and a white plug. The sensors themselves are exactly the same. White plug goes to the sensor on the #2 manifold runner(primary), Green plug goes to sensor on #4 manifold runner(secondary), if you try the opposite way it runs like **** coz the ecu is getting the wrong readings, it's all got to do with primary and secondary not different sensors.
[Modified by crx91, 12:24 AM 2/13/2003]
Old Feb 12, 2003 | 06:08 AM
FourthGenHatch's Avatar
I have a Bosch one, it has worked fine. It was plug and play also.
Old Feb 12, 2003 | 09:55 AM
cursED's Avatar
What application are you guys who actually bought O2 sensors for the JDM B16A1 asking for?
Old Feb 12, 2003 | 12:00 PM
headhunter's Avatar
Default Re: Replacement Oxygen Sensors on B16-- Do you guys recommend a Bosch Universal? (milk)
just replaced my o2 sensors on my jap b16. i used two universal bosch o2 sensors. works great! i can prove it cause before i changed the o2 sensors i failed horribly during emissions. changed both of them and passed everything easily. i was impressed. stick with bosch if you ask me, cheap and works just fine.
Old Feb 12, 2003 | 02:55 PM
paybac4223's Avatar
i used a bosch as a replacement in my infiniti and it works great...
LuvMyHondas
Honda CR-V & Element
Jun 23, 2020 07:12 AM
pimpdaddypat
Dec 28, 2004 03:41 PM
89civic1.8T
Sep 26, 2002 08:21 AM
CLICC916
Apr 13, 2002 12:12 PM
DR. ON POINT
Jan 21, 2002 08:23 AM
