what are these?
Old Feb 10, 2003 | 06:23 PM
Dancing is Forbidden's Avatar
Default what are these?
I have a 1990 B18a and was wondering what this stuff is. What is that circled in the green? And then what is in the pink? TIA
[Modified by EF9_SiR, 3:01 PM 2/13/2003]
Old Feb 10, 2003 | 06:26 PM
The Destroyer's Avatar
Default Re: what are these? (EF9_SiR)
I think the green is sumthing with the t/b. im prob wrong.
Old Feb 10, 2003 | 06:45 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: what are these? (5thgenhybrid)
actually the green is soemthing to do with the throttle body, but what it is idk, i jsu know it came on a b17 throttle body i ahve
Old Feb 10, 2003 | 07:23 PM
Default Re: what are these? (coptzer)
I feel so smart now.
Old Feb 10, 2003 | 07:26 PM
poison's Avatar
I'm not sure on the exact name. But they are vacuum solenoids meant for OBD0 ECU's. A lot of 'em are left disconnected.
Old Feb 11, 2003 | 02:16 PM
Default Re: what are these? (poison)
So I don't need either one?
Old Dec 9, 2005 | 08:12 PM
Default Re: what are these? (ih8jdm)
bump cause I have these on my b16a 3 years later and still don't know what the hell they are.
Old Dec 9, 2005 | 08:40 PM
EGmikeH22's Avatar
* B A N N E D *
try cruise control retards
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtaaak y0 &raquo;</TD></TR><TR><TD CLASS="quote">I think the green is sumthing with the t/b. im prob wrong. </TD></TR></TABLE>
i see where YOUR post count came from!
"hi my name's mike, did someone ask a question? I probably don't know anything but look at that pretty 'post reply' button [*click*]"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">I'm not sure on the exact name. But they are vacuum solenoids meant for OBD0 ECU's. A lot of 'em are left disconnected.</TD></TR></TABLE>
OBD-1 integras came with the one on the left, for cruise control. b18b ls motor, see how its something connected to the throttle body butterfly other than the throttle cable, lets think of what other than your foot affects throttle by way of the main butterfly.
not saying OBD-0 didn't come with it, but not ONLY OBD-0
edit again: solenoid = an electrical device consisting of a wire wrapped around in circles commonly surrounding a magnet, electricity goes through the wire, a magnetic field forms, the magnet moves, like pinball paddles, those are solenoids, vtec solenoid.
vacuum has nothing to do with solenoids.
any more non/mis information
Old Dec 9, 2005 | 09:03 PM
Default Re: what are these? (EGmikeH22)
Im thinking they had to do with automatic tranny as both engine came with auto trannys...
Old Dec 9, 2005 | 09:22 PM
EGmikeH22's Avatar
* B A N N E D *
possibly the center one, but the one on the left IS cruise control
Old Dec 9, 2005 | 10:51 PM
littleredcivic's Avatar
the one in green is a throttle damper. when you let go of the gas, it returns the TB to the fully closed position slowly so the car doesnt stumble. the one in purple..i forgot.
Old Dec 9, 2005 | 11:04 PM
transpar_nt's Avatar
Default Re: (littleredcivic)
bump cuz i'm interested too...
Old Dec 9, 2005 | 11:33 PM
Surewin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGmikeH22 &raquo;</TD></TR><TR><TD CLASS="quote">try cruise control retards</TD></TR></TABLE>
Hey retard, it's not the cruise control!
The green, well, Honda calls it the dashpot diaphragm, and it has nothing to do with the cruise control. Or an automatic transmission.
The pink is called an air boost valve.
Look in the factory service manual for a 90-93 teg, both are fully explained.
Both of these are designed to prevent a rich/lean condition during abrupt throttle changes. OBD-1 ECUs solve this problem electronically, not mechanically like the older engines. OBD-0 D16A6, B18A & B16A have these devices.
Old Dec 9, 2005 | 11:43 PM
Surewin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGmikeH22 &raquo;</TD></TR><TR><TD CLASS="quote">see how its something connected to the throttle body butterfly other than the throttle cable, lets think of what other than your foot affects throttle by way of the main butterfly.
any more non/mis information</TD></TR></TABLE>
Question for EGmikeH22, My 94 Civic has factory cruise control, yet it only has one throttle cable atteched to the butterfly, and nothing else. How does it work?
A: The cruise control cable is hooked up to the gas pedal, not the throttle body.
EGmikeH22's Avatar
* B A N N E D *
OBD-1 b18b has it, cruise control, ask nsxblueteg for pics of his motor (93 ls).
or did i just get owned? anyone else?
Old Dec 10, 2005 | 03:27 AM
91civicDXdude's Avatar
Default Re: (EGmikeH22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGmikeH22 &raquo;</TD></TR><TR><TD CLASS="quote">OBD-1 b18b has it, cruise control, ask nsxblueteg for pics of his motor (93 ls).
or did i just get owned? anyone else?</TD></TR></TABLE>
you got owned, and not only owned, but you look retarded telling other people mis information while bitching about people giving misinformation.
the dashpot on the throttle body makes the throttle not close abruptly when you jerk your foot off the throttle. its supposed to prevent jerking and a lean condition when you suddently release the throttle. the air boost valve (pink) assists in cold starts.
and secondly, 93 integras have a B18A1 OBD1 and not a B18B1. the b18b doesn't have any provisions for either of these.
Old Dec 10, 2005 | 05:38 AM
Default Re: (91civicDXdude)
well I just thought it had something to do with automatic tranny because I have 4 other OBD-0 pr3 intake manifolds and they are all sealed off at the location of the pink circle. Oh well. Thanks guys. The pink one is now disconnected due to it causing a vaccuum leak. Idles much better now
junkyard racer
Dec 1, 2006 03:52 AM
phatrick2332
Jul 25, 2004 09:09 AM
TurboLude97
Feb 13, 2003 05:43 AM
