Vtec solenoid is good.. but still CEL 21..
Old Feb 10, 2003 | 04:48 PM
baonest1's Avatar
Default Vtec solenoid is good.. but still CEL 21..
well i checked like the helms says and i got 14.6X ohms. its supposed to be from 14-30. anyways... i still get the CEL code. now im thinking it might be because the motor (ls/vtec, with OBD1 GSR wiring harness) is in a 2000LS. i have a p30 with hondata and obd2-1 harness. would i need to re-locate a pin on the ECU harness (because its a LS harness inside the car)?? someone has to know somthing. this is the only code i am getting. im fairly new to VTEC so let me know if i need to know anything for future references.,
thanx
Old Feb 10, 2003 | 05:34 PM
Jaker's Avatar
Default Re: Vtec solenoid is good.. but still CEL 21.. (baonest)
Are there wires in the chassis harness leading from the ECU area to the Engine harness for the connections to the Vtec solenoid and Vtec pressure switch? If no mods were made to your chassis harness (other than the adapter) then you need to add wires for the above.
Old Feb 10, 2003 | 05:58 PM
infamousALLMTR's Avatar
Default Re: Vtec solenoid is good.. but still CEL 21.. (Jaker)
ya check the wiring going to the wiring harness this should help (obd-1 ecu)
just splice into where the harness converter wires go to on the ecu diagram, then of course clean it up nice.
[Modified by infamousLSVTEC, 6:59 PM 2/10/2003]
Old Feb 10, 2003 | 06:19 PM
baonest1's Avatar
Default Re: Vtec solenoid is good.. but still CEL 21.. (infamousLSVTEC)
thanx for the info guys... is there a way i can get a biger pic of that image. ima take a look into that.
Old Feb 10, 2003 | 06:25 PM
baonest1's Avatar
would i need to run a wire from the engine harness to the ECU for the solenoid?
also, i guess i have the vtec pressure switch working cuz im not throwing a CEL 22...
Old Feb 10, 2003 | 07:47 PM
Jaker's Avatar
You won't get the code 22, unless the Vtec turns on. The only time the ECU looks to the Vtec pressure switch, is when the ECU turns on the Vtec, and then checks to see if it activated properly, by checking for oil pressure in the Vtec system. If no oil pressure, then it kicks code 22, and shuts off Vtec.
Old Feb 10, 2003 | 07:54 PM
baonest1's Avatar
well i just checked the factory harness on my LS.. and well i followed where the vtec wire is on the adapter harness and there is no pin there.. so i should run a wire from the solenoid to the pin with no wire.. and the save for the pressure switch (has two wires... one is ground.. and other is power. i splice into the power and lead it into the ECU.. and splice into the ground and just ground it on chassis)
thanx
Old Feb 11, 2003 | 06:11 AM
baonest1's Avatar
ima get some wire today and just do a test hookup and see if the light turns off.
waynesumner
Jun 16, 2013 06:36 PM
leftcoast
Aug 9, 2007 08:51 PM
nicko360
Mar 12, 2007 07:12 PM
arielmalespin
Jan 6, 2007 02:52 PM
Peter K
Jun 26, 2002 05:44 AM
