JDM HID ABS Fitment Problems
better sell the headlights to an ITR owner then......
Keep your stupid *** comments to yourself.
You're not going to get much help being an ***. He was kidding, and his post kept your thread at the top for others to notice.
Remember, it was you who cast the first stone:
With that said, here is your original inquiry:
Now how on earth do you expect owners of ITRs (which have smaller ABS units than GSRs) to help you with your problem?
You may want to rethink who is being the moron in this thread.
Thank you, come again.
Hey guys, i just purchased a JDM Conversion with HID's..(OEM)...I have a 1995 GSR with the large ABS thingy...Will it fit? If not, what do i have to do?!
now that the bashings have begun, let's get back on topic, I heard you gotta relocate the passenger side ballast, so you gotta completely remove the casing etc to another location. but there's probably a better way.......
i'd say still sell to a ITR owner......
j/k j/k j/k[Modified by N1-R, 6:21 PM 2/10/2003]
Im not owned, nor am i going to look UP to ITR owners, simply because they are older, and have the money to do so. I rarely come on this ITR forum, BECAUSE itr owners in general think they are better than the rest of the honda-acura world.
That is besides the point.
All i want to know is my original question.
Well i know it will fit, but im really trying to find out if its going to fit with no problems..
Ask this same question in the Integra forum and I'm sure someone will be glad to help you.
I have a 94-97 GSR like yourself, and I am awaiting my JDM front end. In the meanwhile, I have been doing some research, and as you can see in this pic
, there is no way to use the passenger side ballast in the stock location if you have the larger ABS unit.
In short, the ballast has to be relocated.
-Thanks Reid for unlocking it, so that I can post this info-
, there is no way to use the passenger side ballast in the stock location if you have the larger ABS unit.In short, the ballast has to be relocated.
It will fit without removing the large and ugly ABS unit. You WILL have to modify the location of the current AC lines.
Why did Honda reduce the size of the ABS pump/accumulator?
Spec R_GSR
Oct 13, 2007 10:30 AM
Naruto
Feb 1, 2007 07:15 PM
MugenDC4
May 25, 2006 09:38 PM
Rawgie
Jun 23, 2004 10:22 PM
