Gauge cluster light problem
Old Feb 10, 2003 | 01:17 PM
RotiEatter's Avatar
Ditto
Default Gauge cluster light problem
When ever I turn my lights on, the gauge cluster light and air control light don't work. They only work if I am pushing the thing to adjust the brightness of them. Has anyone else had this problem? How did you fix it? Any suggestions? Thanks in advance.
Old Feb 10, 2003 | 02:42 PM
RotiEatter's Avatar
Ditto
Default Re: Gauge cluster light problem (RotiEatter)
bump, for everyone else to see
Old Feb 10, 2003 | 02:53 PM
.jacob's Avatar
Bulb burn out? I had to replace like 5 of mine!
Old Feb 10, 2003 | 03:43 PM
RotiEatter's Avatar
Ditto
Default Re: Gauge cluster light problem (Chiller514)
Bumb, Not bulbs...
Like when you push (I usually punch) in the "Dimmer" switch area, heh, it'll light up till you hit a bump or just shut off again after a few minutes.
I'm thinking about running a switch behind the dashboard and just running all 3 wires to the switch and leaving the switch hidden inside the dashboard.
Old Feb 10, 2003 | 03:45 PM
tominos's Avatar
sounds like your connections are loose at the dimmer switch. just check the wiring and make sure everything is tight.
Old Feb 10, 2003 | 07:56 PM
RotiEatter's Avatar
Ditto
Default Re: Gauge cluster light problem (tominos)
Bump
mikecp
Feb 20, 2011 08:52 PM
xxjasonxx
Nov 20, 2008 06:08 PM
BYAAH85
Feb 19, 2008 11:35 AM
memorybox
Sep 11, 2006 06:42 AM
D@nnY
Mar 4, 2004 07:07 PM
