91 rear disk on an 88 crx
Old Feb 10, 2003 | 12:12 PM
spun Vtec's Avatar
Default 91 rear disk on an 88 crx
can this be done i dont see why not being that there are only small diffrences with the 88 susp.
thanks
-larry
Old Feb 10, 2003 | 12:40 PM
Hondasaurs's Avatar
Default Re: 91 rear disk on an 88 crx (4gsicivichatch)
You can swap out the rear trailer arms froma 90-91 SI
Old Feb 10, 2003 | 01:06 PM
Outsane's Avatar
it can and has been done several times..
Old Feb 10, 2003 | 01:49 PM
BMacls's Avatar
you can youse some intragre to
Old Feb 10, 2003 | 03:56 PM
CRX Lee's Avatar
I did it on a CRX racecar by swapping out the spindles and parts from the trailing arms and not the complete arms. IMO, there was no performance gain and the disc system is 8 lbs heavier. You must change the proportioning valve too and the master cylinder should be changed at that time as well or you will have a long ppedal.
I've had all the parts in the basement for years to do another swap but haven't because the reward isn't worth the effort. BTW, the 90-91 CRX Si rear brakes are the same as the 90-03 Integra rears but they are just so small that they don't really do much.
jacksonww
Feb 7, 2011 11:09 AM
crxhftosi
Jan 30, 2005 10:13 PM
BOSS-REX
15
Oct 2, 2004 03:56 PM
Jamison182
Apr 7, 2003 07:11 PM
spettinger
Jul 10, 2002 04:10 PM
