Are all b-series oil pans the same?
Old Feb 10, 2003 | 09:01 AM
MeanGreenEG9's Avatar
Default Are all b-series oil pans the same?
I thought the LS oil pan was different from the gsr's.. but my actual question is the one for the gsr b18c1 the same as the one for civic si b16a? same gasket? TIA
Old Feb 10, 2003 | 09:20 AM
advanracing62's Avatar
Default Re: Are all b-series oil pans the same? (B16aEJ)
Yes and No.... The baffeling is a bit different. The bolt holes line up and you can bolt one onto the other.
Old Feb 10, 2003 | 09:27 AM
turbodsmpower's Avatar
Default Re: Are all b-series oil pans the same? (advanracing62)
b16 oil pans are different as well look at them carefully your pickup tube may not fit w/ the spare pan you are trying to use
Old Feb 10, 2003 | 10:29 AM
Cory man's Avatar
Default Re: Are all b-series oil pans the same? (turbodsmpower)
I may be wrong but the b18c pans are deeper because of the block girdle. I read somewhere that the itr and gsr pans are the same and that the b20, b18a/b and the b16a pans are the same.
Old Feb 10, 2003 | 11:56 AM
Default Re: Are all b-series oil pans the same? (Cory man)
no they are not i had trouble w/ b16 pans and the pickup and pans are slight difference
Old Feb 10, 2003 | 12:16 PM
salbaje's Avatar
they are different the gsr pans are deeper
Old Feb 10, 2003 | 12:49 PM
sgT's Avatar
sgT
Default Re: Are all b-series oil pans the same? (salbaje)
b16a/b17a/b18a/b/b20b/z all use teh same pan
B18C pans are different and are the only ones stamped with P72. the others have no stamp
BoostnEK6206
Mar 23, 2008 02:51 PM
1SIKCRX
Jul 7, 2004 07:59 PM
kolumbo69
Jun 15, 2004 11:00 AM
yellow blur
Apr 14, 2003 05:43 PM
slwazgsr
Sep 3, 2002 06:47 AM
