Jdm final drive what quaife?
Old Feb 9, 2003 | 09:49 PM
littlebluecrx's Avatar
Default Jdm final drive what quaife?
O.k. a friend has been asking me to get him a quaife, he has a jdm finaldrive gear set, it has all the bearing's for the swap."I have not seen the bearing part# so dont light my *** up for it "My question is he has a b16 hydro trans, I thought the jdm final needs a gsr quaife, can it work in a b16 case, if diff bearings, and the pinion shaft are meant for the jdm ring gear? I am tired so I am not speaking clearly , any info would be appreciated, I thought jdm final drive was meant to bolt on factory lsd, and would not bolt to a quaife. Thanks Jason
Old Feb 9, 2003 | 10:47 PM
rice a rona's Avatar
Default Re: Jdm final drive what quaife? (littlebluecrx)
the ls and b16a quaifes no matter if they are hydo or cable are the same. The typr r and gsr are the same. I think all the finals bolt up right?
Old Feb 10, 2003 | 12:10 AM
simple4012's Avatar
New User
Default Re: Jdm final drive what quaife? (top notch)
jason, you need the gsr quaife for the jdm itr fd.
Old Feb 10, 2003 | 01:45 AM
H25's Avatar
H25
Default Re: Jdm final drive what quaife? (simple4012)
yea thats correct, gsr or type r diff or lsd to fit a jdm 4.7 final ring gear.
Old Feb 10, 2003 | 06:01 AM
tony1's Avatar
That's correct, and it will fit in the b16 case as long as you use the b16 diff. bearings.
Old Feb 10, 2003 | 06:39 AM
CHEETAH's Avatar
Default Re: Jdm final drive what quaife? (tony1)
yup, and shim if necessary. Transfer the upper carrier bearing shim to the bottom casing, pop out seals and check with feeler guage.
greg
Old Feb 10, 2003 | 09:23 AM
Default Re: Jdm final drive what quaife? (CHEETAH)
All of you thank you very much, I thought he needed gsr quaife, but did not want to be wrong because we cant return it if it is wrong. Thanks Jason
J Mira
Jul 17, 2008 01:21 AM
kartoos
Feb 24, 2007 01:49 PM
vteec
Apr 22, 2004 12:04 PM
Nice_Dc2r
Jul 5, 2003 07:58 PM
shamoo
Mar 15, 2002 06:33 PM
